- Release notes
 - Before you begin
 - Getting started
 - Managing access
 - Working with process apps
 - Creating process apps
 - Loading data
 - Customizing process apps
 - Data transformations
 - TemplateOne app template
 - Purchase to Pay app template
 - Order to Cash app template
 - Basic troubleshooting guide
Process Mining
If your data for cases and events is available in one input file, you use the TemplateOne-SingleFile app template.
If you want to create a new TemplateOne process app, you must upload a dataset that contains the data to be used in the TemplateOne.
.tsv (tab-separated) file or .csv (comma-separated) file that contains a column for each input field.
               Event_log.
                  If you are extracting the data using CData Sync, `_raw` has to be added to the table names listed below, e.g. `Event_log_raw`.
Tutorial
When creating your first dataset, check this video below for a tutorial. Use this to better understand how to create a dataset and use it in a TemplateOne process app.
Your input data file can have different fields or different field names. However, there are some fields mandatory for TemplateOne - SingleFile, which means that the data must be available in your input data file for a correct working of TemplateOne.
NULL values.
               Field types
Below is an overview of the different field types and their default format settings.
                                  Field type  |
                                  Format  |
                                  boolean  |
                                 true, false, 1, 0 |
                                  datetime  |
                                 yyyy-mm-dd hh:mm:ss[.ms], where [.ms] is optional.
                                  double  |
                                  Decimal separator:
                                 . (dot)
                                 Thousand separator: none  |
                                  text  |
                                  N/A  |
                                  integer  | Thousand separator: none
This page contains an overview of the input fields for TemplateOne - Single File. For each field, the name, the data type, and a short description are displayed. Apart from that, it is indicated whether the field is mandatory.
Below is an overview of the input fields for TemplateOne.
                               Name  |
                               Data type  |
                               Mandatory Y/N  |
                               Description  |
                               text  |
                               Y  |
                               The name of the event. This describes the step in the process.  |
                               text  |
                               Y  |
                               The unique identifier of the case the event belongs to.  |
                               datetime  |
                               Y  |
                               The timestamp associated with the end of executing the event.  |
                               boolean  |
                               N  |
                               Indicates whether the event is manually executed or automated.  |
                               text  |
                               N  |
                               A user-friendly name to identify the case.  |
                               text  |
                               N  |
                               The status of the case in the process. For example, open, closed, pending, approved, etc.  |
                               text  |
                               N  |
                               The categorization of the cases.  |
                               double  |
                               N  |
                               A monetary value related to the case.  |
                               double  |
                               N  |
                               The costs for executing the event.  |
                               text  |
                               N  |
                               Information related to the event.  |
                               datetime  |
                               N  |
                               The timestamp associated with the start of executing the event.  |
                               text  |
                               N  |
                               The team that executed the event.  |
                               text  |
                               N  |
                               The user who executed the event.  |
Additionally, custom case and event fields for both case and event properties are available for TemplateOne.
- 30 fields of type text;
 - 10 fields of type double;
 - 10 fields of type datetime;
 - 10 fields of type boolean;
 - 15 fields of type duration.
Custom fields have generic names. Below is an overview of the custom fields that can be used in a process app.
                               Name  |
                               Data type  |
                               Mandatory Y/N  |
                               custom_case_text_{1...30}  |
                               text  |
                               N  |
                               custom_case_number_{1...10}  |
                               double  |
                               N  |
                               custom_case_datetime_{1...10}  |
                               datetime  |
                               N  |
| custom_case_boolean_{1...10} |
                               boolean  |
                               N  |
                               custom_event_text_{1...30}  |
                               text  |
                               N  |
                               custom_event_number_{1...10}  |
                               double  |
                               N  |
                               custom_event_datetime_{1...10}  |
                               datetime  |
                               N  |
                               custom_event_boolean_{1...10}  |
                               boolean  |
                               N  |
                               custom_event_duration_{1...5}  | integer | N |
When you use a custom field, you should rename the field in using Data manager to a name that matches the value. See Fields.
Custom fields that are empty in your dataset, are not displayed in Process Mining.
