- Release notes
- Before you begin
- Getting started
- Managing access
- Working with process apps
- Creating process apps
- Loading data
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining
System requirements
linkIntroduction
linkUsing DataBridgeAgent requires a UiPath Process Mining server installation. This page gives an overview of the system requirements for the Process Mining server on which you want to use DataBridgeAgent to load data for Process Mining.
If you want to install UiPath Process Mining or any of its components, you need access to an environment, and you need a UiPath Process Mining license. Please consult your UiPath Process Mining contact.
DataBridgeAgent does not require a separate license.
Server OS
Process Mining is a 64-bit program and requires a 64-bit environment. For production systems the following operating systems are supported:
- Windows 10
- Windows Server 2019
- Windows Server 2016
Windows Server 2012 R2
Minimum Ssystem requirements
Below is an overview of the minimum system requirements:
Component |
Minimal size |
Description |
CPU |
1 core |
Strong single-core performance is recommended. |
Memory |
32 GB | |
Storage |
variable |
The disk needs to be large enough for the operating system, UiPath Process Mining, the data, and cache files. DataBridgeAgent uses less than 1GB. |
