Last updated Oct 8, 2025
Patch artifact download links
This page provides the download links for the artifacts required to apply a patch.
2024.10.3 patches
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2024.10.3 patches.
2024.10.3+patch1
as-cmk.tar.gz
To download as-cmk.tar.gz for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch1/as-cmk-2024.10.3+patch1.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.3+patch1/as-cmk-2024.10.3+patch1.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/air-images.txt
as-helm-charts.txt
To download embedded-helm-charts.txt for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3+patch1/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2024.10.3+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3+patch1/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3+patch1/versions.json
2024.10.2 patches
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2024.10.2 patches.
2024.10.2+patch1
as-cmk.tar.gz
To download as-cmk.tar.gz for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.2+patch1/as-cmk-2024.10.2+patch1.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.2+patch1/as-cmk-2024.10.2+patch1.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/air-images.txt
as-helm-charts.txt
To download embedded-helm-charts.txt for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2+patch1/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2024.10.2+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.2+patch1/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.2+patch1/versions.json
  • 2024.10.3 patches
  • 2024.10.3+patch1
  • 2024.10.2 patches
  • 2024.10.2+patch1
