- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Deployment architecture
You can reference the following architecture diagrams to deploy Automation Suite on OpenShift.
The OpenShift architecture comprises the control plane nodes and the compute nodes. The control plane nodes host the control plane applications of Kubernetes, such as API servers, etcd, schedulers, etc., whereas the compute nodes host other applications like the monitoring stack, networking, etc. Automation Suite is also installed on the compute nodes.
Automation Suite relies on Istio for networking and ArgoCD for deployment. You can replace Istio with the OpenShift Service Mesh and ArgoCD with the OpenShift GitOps Operator.
The following components are also required:
- Redis
- An S3-compatible objectstore
- Microsoft SQL Server
- Block storage
You can meet the Redis requirement by using the Redis Enterprise Operator from OpenShift or installing High Availability Add-on on separate machines.
You can use OpenShift Data Foundation for the S3 Objectstore buckets and the block storage.
