- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
Automation Suite API guide
Last updated Feb 24, 2025
Returns information about a robot account, based on the organization and robot account ID.
GET https://{yourDomain}/{organizationName}/identity_/api/RobotAccount/{partitionGlobalId}/{robotAccountId}--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'Note: To obtain the
{access_token}, make sure to authenticate through one of the methods described here.
Path param |
Data type |
Description |
(required) |
String |
The ID of the organization containing the desired group. |
(required) |
String |
The ID of the robot account you want to retrieve. |
200 OK
The specified robot account information is returned, such as name, creation time, and the group IDs the account is part of.
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is:https://{yourDomain}/{organizationName}/{tenantName}/ -
Your
{access_token}is:1234(for length considerations). - The
{partitionGlobalId}is:magic-7 - The
{robotAccountID}is:33-ab
The call should resemble the following example (cURL):
curl --location --request GET 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7/33-ab' \
--header 'Content-Type: application/json'curl --location --request GET 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7/33-ab' \
--header 'Content-Type: application/json'Here's the response body for a successful call:
"id": "33-ab",
"name": "Bot3",
"displayName": "Bot3",
"creationTime": "2021-10-19T14:25:01.6574988",
"lastModificationTime": "2021-10-19T14:25:01.6574988",
"groupIds": [
"4d161738-7204", "ce684f6f-5af3"
"id": "33-ab",
"name": "Bot3",
"groupIds": [
