  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Automation Suite API guide
Last updated Feb 24, 2025
Get Audit Logs
Gets the audit logs for an organization, based on the organization name.
API Endpoint
GET https://{yourDomain}/audit_/api/auditlogs
Scopes
Requires the following scopes:
  • PM.Audit
  • PM.Audit.Read
Request Headers
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
Query Parameters
Query param
Data type
language
(optional)
string
Specify the available display language, in the shorten form.
For example, en, fr, de, ja etc.
top
(optional)
int32
Display the top N entries of the audit.
skip
(optional)
int32
Skip the top N audit entries from displaying.
sortBy
(optional)
string
Specify the DTO property used to sort audit entries by.
For example, createdOn, category, email, etc.
sortOrder
(optional)
string
Specify the sorting order.
For example, ascending (asc) or descending (desc).
api-version
(optional)
string
Specify the API version you are using.
Responses
200 OK
Returns the queried audit events.
Example Request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}
  • Your {access_token} is: 1234 (for length considerations).
  • You set the following query params:
    • language = en
    • top = 2, to display the top two entries
    • skip = 2, to skip the first two entries
    • sortBy = createdOn, to sort the entries by their creation time
    • sortOrder = asc, to sort the entries from the earliest entry to the latest one
The call should resemble the following example (cURL):
curl --location --request GET ' https://{yourDomain}/{organizationName}/audit_/api/auditlogs/?language=en&top=2&skip=2&sortBy=createdOn&sortOrder=asc' \
--header 'Content-Type: application/json'curl --location --request GET ' https://{yourDomain}/{organizationName}/audit_/api/auditlogs/?language=en&top=2&skip=2&sortBy=createdOn&sortOrder=asc' \
Here's the response body for a successful audit entries retrieval:
    "totalCount": 29,
    "results": [
            "createdOn": "2021-10-14T13:10:15.1964174+00:00",
            "category": "User",
            "action": "Login",
            "auditLogDetails": "{\r\n \"userName\": \"System Administrator admin\",\r\n \"email\": \"\"\r\n}",
            "userName": "System Administrator",
            "email": "",
            "message": "User 'System Administrator admin' logged in",
            "detailsVersion": "1.0",
            "source": "Cis"
            "createdOn": "2021-10-14T12:41:00.3268964+00:00",
            "category": "User",
            "action": "Login",
            "email": "",
            "source": "Cis"
    "totalCount": 29,
    "results": [
            "category": "User",
            "action": "Login",
            "email": "",
            "source": "Cis"
            "category": "User",
            "action": "Login",
            "email": "",
            "source": "Cis"
  • API Endpoint
  • Scopes
  • Request Headers
  • Query Parameters
  • Responses
  • 200 OK
  • Example Request
