- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- AI Trust Layer
- About AI Trust Layer
- Managing AI Trust Layer
- Working with Context Grounding
- Context Grounding licensing
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
This section includes information on how to use Context Grounding effectively.
You can manage the ingestion pipelines through:
- Directly in Orchestrator, from the Indexes page. See Managing indexes.
- The Update Context Grounding Index activity, part of the UiPath GenAI activities package.
After creating an index in Orchestrator, indexes are accessible throughout the UiPath platform. These indexes serve as persistent storage for documents ingested from your data sources, offering a reusable resource for various UiPath products:
- In Autopilot for Everyone, Context Grounding enhances user interactions by enabling searches across existing indexes to provide accurate answers to queries. For details, refer to Context Grounding in Autopilot for Everyone.
- GenAI Activities benefit from Context Grounding by allowing content generation based on information stored in permissioned knowledge bases. For details, refer to GenAI Activities.
Monitoring Context Grounding
Understanding how Context Grounding influences your workflows is crucial for optimizing performance and troubleshooting. Here's how you can trace and view Context Grounding outputs across different UiPath products.
In Agents, access the Trace view of the agent run to see comprehensive details. This view provides all search results and citations from the Context Grounding query, offering insights into the agent's decision-making process.
To gather detailed information about Context Grounding in GenAI activities:
- Place a Log Message activity immediately after the Content Generation activity in your workflow sequence.
- Use the following output
variables to capture specific information:
- Top Generated Text: View the LLM generation response after workflow execution.
- Citations: Examine the semantic search results that influenced the generation output. This works only for PDF and JSON data types.
The core components of Context Grounding are designed to provide a mechanism that supports finding pertinent information within and across documents, and surfacing only the most relevant pieces needed for a high-quality, low-latency generation from an LLM.
Searching within documents
The Context Grounding service helps you find specific information within a single document more effectively. Instead of just matching keywords, it understands the meaning and context of your search query. For example, if you're looking for information about "apple pie recipes" in a cookbook, it would understand that you're interested in desserts and baking, not technology or fruit farming.
Searching across documents
Context Grounding helps you find information spread across multiple documents. It can understand the relationships between different pieces of information and provide more relevant results. For example, if you're researching "climate change effects on agriculture" across various scientific papers, it pulls together relevant information from multiple sources, understanding that topics like rainfall patterns, crop yields, and temperature changes are all related to your query.
This means you can use Context Grounding for:
Data extraction and comparison: Context Grounding can automatically identify and extract specific types of information from documents, then compare them in meaningful ways. Imagine you have a stack of résumés and want to compare candidates' work experiences. The service could extract job titles, durations, and responsibilities, then present them in a way that makes comparison easy, even if the information is formatted differently in each résumé.
Summarization: Context Grounding can create summaries of long documents or multiple related documents. It doesn't pick out random sentences, but understands the key points and overall message. For example, if you have a long report on market trends, the service can provide a summary highlighting the main findings, key statistics, and overall conclusions.
You can subscribe to receive notifications from Context Grounding. Visit Notifications panel to learn more.
Events serve as triggers for notifications. The Context Grounding events that generate notifications are:
- Ingestion Job Completed
- Ingestion Job Failed
- Ingestion Job Started
You can also subscribe to events based on their severity, such as Success or Error.
What is Context Grounding?
Context Grounding is a new UiPath® feature, part of the AI Trust Layer. It provides a mechanism to search and retrieve relevant context from data to ground prompts and guide more precise generations from large language models (LLMs) through UiPath GenAI features and products.
Why is Context Grounding important?
Context Grounding provides evidence via user-provided data to LLMs to influence their generations. This makes predictions more tailored to your use cases and data, rather than based on the general data upon which LLMs are trained. This allows both attended and unattended automations which leverage GenAI to be more accurate and precise.
How does Context Grounding work?
Context Grounding provides two services:
- Managed Vector DB as a Service: We make it easy for you to convert your data into embedding representations.
- Retrieval Augmented Generation (RAG) as a Service: Context Grounding queries data from various automation products, retrieves the most relevant results, and augments prompts with those results to ensure generations are more specific.
How do I use Context Grounding?
You can use Context Grounding through UiPath GenAI Activities and Autopilot for Everyone.
Does Context Grounding eliminate hallucinations?
No, but it does significantly reduce the likelihood of hallucinations because generations are based on information queried from user-provided data. By default, Context Grounding provides a citation, or proof of knowledge, from which the generation was based. This means you can verify and validate the source. When Context Grounding isn't able to find a highly confident corresponding answer in the provided data, it does not try to make up answers. Instead, it generates a response such as: "An answer could not be found".
Do I have access to Context Grounding?
Context Grounding is accessible to all tenants and organizations.
How is Context Grounding licensed?
Context Grounding charges for searches or RAG as it is executed through its supported UiPath product surfaces. For details, refer to Context Grounding licensing.
Is Context Grounding available only in cloud deployments?
No. Starting with the 2.2510 release, Context Grounding is also available in Automation Suite.
What types of data can I use in Context Grounding?
Context Grounding currently works the following data formats: PDF, JSON, CSV, DOCX, TXT, XLS.
Can I import additional business data into Context Grounding?
To leverage Context Grounding, you need to import data into UiPath Orchestrator storage buckets (via direct upload, Studio activity, or API).
You can then use Context Grounding activities to ingest and index, and manage the queried data to ensure highly relevant results.
Is there a limit on the amount of data I can include in Context Grounding?
- Index limit: There is a limit of ten indices per tenant. We recommend you maintain a 1-1 relationship between Orchestrator buckets from which you are ingesting data to prevent data leak across folders and ensure logical separation of data that may need to be queried by different users for different purposes. Context Grounding takes advantage of folder authorization permissions to help enforce this recommendation.
- Storage: There is no limit on storage across or within these indices. However, we impose some limits on customers who have exceedingly high amount of data ingested.
Is Context Grounding the same as RAG?
Context Grounding does provide a RAG service at runtime for UiPath GenAI experiences. However, it also provides a managed vector database as a service to help manage the data used at runtime. This guarantees a high-quality search and generated results.
How is my data stored or shared with Context Grounding?
All data shared with UiPath is treated with standard enterprise compliance, encryption, and security standards.
Context Grounding is part of the AI Trust Layer, which means your data is never stored outside of UiPath, nor is it used to train third-party models.
How do you ensure data security?
Context Grounding is tenant-scoped and takes advantage of existing RBAC and AuthZ policies in UiPath, in addition to encrypting data at rest and in transit.
Because it is tenant-scoped, no data is shared across indices within the same tenant or across tenants.
How is Context Grounding permissioned?
Context Grounding is tenant-scoped. We support folder-level authorization in Orchestrator buckets, and Context Grounding leverages existing authentication and Automation Ops policies applied to the GenAI Activities.
Can I dynamically select which LLM to use?
In the UiPath GenAI activities you can select which LLM to use for executing the RAG portion that Context Grounding supports. You can select any LLM available in the LLM Gateway (part of the UiPath AI Trust Layer). UiPath then manages the ingestion and semantic search strategies to optimize the generation.
