- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- AI Trust Layer
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
Organization administrators can view, add, edit, or remove accounts and groups for the organization from the Accounts & local groups page at the organization level.
You can add new local groups if you want to define a custom mix of roles and license allocation rules to use for a particular group of accounts. For example, the ones needed by your colleagues in the Accounting department to use the UiPath platform.
For information about the different account types, refer to About accounts and groups.
Creating user accounts
For information about working with user accounts, refer to Managing user accounts.
Creating robot accounts
To create a robot account, take the following steps:
The robot account is added and is now visible on the Robot accounts page. It is also added to the groups you selected.
To remove an account or group, take the following steps:
- Go to Admin and select the organization at the top of the panel on the left.
- Select Accounts & local groups.
- To remove a user account, select the User accounts tab. Alternatively, to remove a local group, select the Local groups tab.
- Look for the user account or group you want to remove, then at the right end of the row, select the three-dot button, then choose Delete.
- Confirm the action in the confirmation dialog.
Alternatively, you can remove accounts and groups using the user and group profiles. For details, refer to Managing user and group profiles.
As an organization admin, you can manage user and group profiles from a single location that allows you to customize group memberships, handle licenses, monitor access, and update user and group info.
To access user and group profiles, navigate to Admin > Accounts & local groups > User accounts, then select the user account or group you want to manage.
Managing user profiles
To manage the profile of a user account, navigate to Admin > Accounts & local groups > User accounts, then select the user account you want to manage. You can perform the following operations:
In the Group memberships tab: View, add, or remove group memberships.
In the Licenses tab: View, assign, or remove license allocation.
In the Access tab: View or export details on permissions and role assignment.
In the Info tab: Rename or delete local users.
Note:You cannot delete or rename directory users or the last admin.
As a safety method, any organization must have at least one organization admin. This means that you cannot delete the last organization admin, nor can you remove the role assignments for the last user that has this role.
Managing group profiles
To manage the profile of a user group, navigate to Admin > Accounts & local groups > Local groups, then select the group you want to manage. You can perform the following operations:
In the Members tab: Add or remove users to or from a local group.
Note:All local or directory users added to Automation Suite are part of the Everyone group. You cannot view the members in the Everyone group.
Important: Known limitation: The search results for local group members are not displayed beyond the first page, regardless of whether the query matches the search result. -
In the Access tab: View or export access details.
In the Group info tab: Rename or delete local groups.
Note:You cannot delete or rename directory groups or built-in groups (Everyone, Automation Users, Administrators, etc.).
