- Open API- Introduction to Automation Hub API
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
- Automation Hub Custom Connector
Automation Hub API Guide
Last updated Jul 3, 2024
Note: For the POST call made to update an idea phase and status do not use the phase or status keys.
         | Key | Phase name | Phase ID |
| IDEA | Idea | 1 |
| ASSESSMENT | Assessment | 2 |
| QUALIFICATION | Qualification | 3 |
| ANALYSIS | Analysis | 4 |
| SOLUTION_DESIGN | Solution Design | 5 |
| DEVELOPMENT | Development | 6 |
| TESTING | Testing | 7 |
| HYPERCARE | Hypercare | 8 |
| LIVE | Live | 9 |
| BUSINESS_REVIEW | Business Review | 10 |
| TECHNICAL_REVIEW | Technical Review | 11 |
Example: phase=2
UI Correspondent:
               Automation Phase and Status
