test-suite
Test Suite User Guide
Last updated Apr 15, 2025
Packing Projects Into a Package
Prerequisites:
  1. Run the package task, using uipcli package. You can see a list of the available sub-tasks.
  2. Specify the required parameters and run the pack sub-task.
    See the list of parameters below.
Note:
Project validation is not performed by the Pack or Analyze tasks of UiPath CLI.
Legend: (*) - Optional, useful only when you have dependencies from a library in Orchestrator.
Parameter
-o, or --output (Required)
The destination Orchestrator folder, where you want to package the projects.
-v, or --version
Set the package version.
--autoVersion
Auto-generates a package version.
--outputType
Forces the output to be a specific type.
--splitOutput
Enables the output split to runtime and design libraries.
--repositoryUrl
The repository URL where the project is versioned.
--repositoryCommit
The repository commit where the project was built from.
--repositoryBranch
The repository branch where the project was built from.
--repositoryType
VCS system repository type.
--projectUrl
Automation Hub idea URL.
--releaseNotes
Add release notes.
--libraryOrchestratorUsername (*)
(Required if you use Basic Authentication, through a username and a password)
The username used for authenticating to Orchestrator. You must pair it with the corresponding password.
This is required if your package references libraries from Orchestrator feed
--libraryOrchestratorPassword (*)
The password used for authenticating to Orchestrator. You must pair it with the corresponding username.
--libraryOrchestratorAuthToken (*)
(Required if you use token-based authentication)
The OAuth2 refresh token used for authenticating to Orchestrator. You must pair it with the Account Name and Client ID.
--libraryOrchestratorAccountName (*)
The Orchestrator CloudRPA account name. You must pair it with the OAuth2 refresh token and Client ID.
--libraryOrchestratorAccountForApp (*)
The Orchestrator CloudRPA account name(organization name). You must pair it with the Application ID,Application Secret, and Application scope for external application
This is required if your package references libraries from Orchestrator feed.
--libraryOrchestratorApplicationId (*)
The external Application ID. You must pair it with the Application Account, Application Secret, and Application scope.
--libraryOrchestratorApplicationSecret (*)
The external Application Secret. You must pair it with the Application Account, Application ID, and Application scope.
--libraryOrchestratorApplicationScope (*)
The list of application scopes, separated by single spaces. You must pair it with the Application Account, Application ID, and Application Secret for external application.
--libraryOrchestratorFolder (*)
The name of the target Orchestrator folder.
To input subfolders make sure to input both the parent folder name and the name of the subfolder. For instance, use AccountingTeam\TeamJohn.
--libraryOrchestratorUrl (*)
The URL of the Orchestrator instance.
--libraryOrchestratorTenant (*)
The tenant of the Orchestrator instance where you want to delete a machine.
--libraryIdentityUrl(Required only for PaaS deployments)
The URL of your identity server.
-y, or --disableTelemetry
Disable telemetry data.
--traceLevel
Display the trace of the events.
-l, or --language
The language used in the Orchestrator user interface.
--disableBuiltInNugetFeeds
Disable built in nuget feeds.
--help
Displays the parameters and examples for this command.
--version
Display version information.
Project(s) Path (pos. 0) (Required) The path to a project.json file, or to a folder that contains project.json files.
Usage:
package pack <project_path> -o <destination_folder> [-v <version>] [--autoVersion] [--outputType <Process|Library|Tests|Objects>] [--libraryOrchestratorUrl <orchestrator_url> --libraryOrchestratorTenant <orchestrator_tenant>] [--libraryOrchestratorUsername <orchestrator_user> --libraryOrchestratorPassword <orchestrator_pass>] [--libraryOrchestratorAuthToken <auth_token> --libraryOrchestratorAccountName <account_name>] [--libraryOrchestratorFolder <folder>] [-l <language>]package pack <project_path> -o <destination_folder> [-v <version>] [--autoVersion] [--outputType <Process|Library|Tests|Objects>] [--libraryOrchestratorUrl <orchestrator_url> --libraryOrchestratorTenant <orchestrator_tenant>] [--libraryOrchestratorUsername <orchestrator_user> --libraryOrchestratorPassword <orchestrator_pass>] [--libraryOrchestratorAuthToken <auth_token> --libraryOrchestratorAccountName <account_name>] [--libraryOrchestratorFolder <folder>] [-l <language>]
Examples:
  • package pack "C:\UiPath\Project\project.json" -o "C:\UiPath\Package"
  • package pack "C:\UiPath\Project\project.json" -o "C:\UiPath\Package" -v 1.0.6820.22047
  • package pack "C:\UiPath\Project\project.json" -o "C:\UiPath\Package" --autoVersion
  • package pack "C:\UiPath\Project" -o "C:\UiPath\Package"
  • package pack "C:\UiPath\Project\project.json" -o "C:\UiPath\Package" --outputType Tests -l en-US
Adding an External Application
To register an external application so that it can access your UiPath resources using OAuth:
  1. Log in to the tenant as an Administrator.
  2. Go to Tenant > Manage access > Assign roles and select Manage Accounts & Groups.
    The tenant-level opens.
  3. Along the left, select External Applications.
    The External Applications page opens, listing all the existing external applications registered for the current tenant:
  4. Select Add Application.
  5. Fill in the Application Name field.
  6. Select an option for Application Type.
    If you select Confidential application, you receive an app secret at the end, so make sure your application can store it securely. If it can't, select Non-confidential application.
  7. Under Resources, select Add Scopes.
    The Edit Resource panel opens on the right, where you can select the resources to which the application should have access.
  8. From the Resource drop-down list, select the UiPath API that the application can use.
    Note: You can only add scope for one resource at a time. If you want to allow access to multiple resources, repeat this process to add scope for each resource.
  9. On the User Scope(s) tab, select the check boxes for the logical API permissions that you want to grant, as needed.
    Granting permissions under user scope means that the external application can access those resources within a user context and a user with the appropriate permissions must be logged in.
  10. If this is a confidential application, you can switch to the Application Scope(s) tab to also grant application-level permissions for the selected resource, as needed.
    With permissions under application scope, the external application has access to application-wide data for the selected scopes without the need for user interaction.
    Non-confidential applications cannot access application scope.
  11. Select Save.
    The panel closes and the selected resource and scopes are added to the Resources table in the form.
  12. If the external application can accept it, you can add a URL in the Redirect URL field and the authorization response is sent there. The application can then use it to access UiPath resources.
  13. Select Add to create the registration.
    A confirmation message opens. For confidential applications, the confirmation message includes the app secret that the registered external application can use to request authorization. Make sure you save it in a secure location because you cannot revisit it.
  • Adding an External Application
