EXPLORE:
Design and create your own automations with UiPath Studio Web, whatever your level of expertise.
Start automating now!
Documentation
search
Search
rate_review
Feedback
notifications
Subscribe
Log in
Sign up
search
test-suite
- Collapse
Getting Started
Introduction
Capabilities
RPA Testing
Best practices
Test automation
Studio
Testing Activities
Mobile device automation
About the mobile device automation architecture
Getting started
Managing Mobile Device Manager
Managing devices
Cloud devices
Local Android devices
Local iOS devices
Configuring local iOS simulator
Managing applications
Creating mobile automation workflows
Device Interaction
Troubleshooting
Debugging
Logs and Execution Timeline
Troubleshooting scenarios
Automation for React Native apps
Mobile automation activities
SAP Solution Manager Integration
Setup and configuration
Configuring user machine
Configuring SAP Solution Manager
Configuring system under test
SAP Solution Manager command line
Use case scenarios
Orchestrator
Orchestrator
Testing in Orchestrator
Testing robots
Testing robot license
Test Manager
Getting started
Integrating with Studio
Creating a project
Licensing Test Manager
ALM tool integration
UiPath Test Manager Connect
Out-of-the-box connectors
Atlassian Jira
Xray for Jira
Azure DevOps
ServiceNow
Webhooks
Redmine Integration
Heatmap
Prerequisites
Direct connection to SAP instance
Upload SAP data from CSV file
Working with Heatmap
Requirements
Test cases
Assigning test cases to requirements
Linking test cases in Studio to Test Manager
Unlinking automation
Delete test cases
Document test cases with Task Capture
Create test cases
Cloning test cases
Automate test cases
Manual test cases
Test sets
Executing Tests
Test Results
Documents
Reports
Export data
Bulk operations
Product configuration
User and Group Access Management
Custom fields
Application settings
My notifications
Subscribing to events
Unsubscribing from events
Telemetry
Import project
Export project
Troubleshooting
Test Manager API integration
Integrating your tool with Test Manager
API Scopes
Test Manager API
API version
Test Manager URL
API references
Permissions
CI/CD Integrations
Available third party integrations
UiPath CLI
CLI Tasks
Executing Tasks
Deleting Assets From Orchestrator
Deploying Assets to Orchestrator
Running a job inside Orchestrator
Analyzing a Project
Deleting a Package
Deploying a Package to Orchestrator
Packing Projects Into a Package
Testing a Package/Running a Test Set
Azure DevOps Extension
Service Connection Configuration
Job Tasks
Jenkins Plugin
Jobs
Troubleshooting Jenkins Plugin
Home
Creating a project
Home
Test Suite
Automation Suite
Creating a project
Test Suite User Guide
DELIVERY:
Automation Suite
RELEASE:
Last updated Apr 15, 2025
On this page
Conditions
Who can create projects
Navigation and search
Create project
thumb_up
Yes
thumb_down
No
PREVIOUS
NEXT
Support and Services
UiPath Academy
UiPath Forum
English
Terms of Use
Privacy Policy
Cookies Policy
