- Getting started
- Project management
- Project operations and utilities
- Test Manager settings
- User and Group Access Management
- Custom fields
- Telemetry
- ALM tool integration
- API integration
Test Manager user guide
Access management is handled by the Test Manager Administrator that can assign tenant roles to users and groups, as well as create custom project roles, and Project Owners that can assign project roles to users and groups.
- Tenant - these roles are relevant at tenant level.
- Project - these roles are relevant at project level.
Tenant roles define the actions that a user or group can perform in the target tenant, regardless of the project roles they have assigned. These roles involve the ability of creating projects, creating custom roles, and assigning roles to users or groups.
The table below shows the available tenant roles and their corresponding descriptions.
| Tenant role | Description |
| Administrator | A Test Manager administrator can perform the following actions:
| Project Creator | A Project Creator can create testing projects.
If you want non-administrator users to create projects without granting them administrator privileges, you can assign them only the Project Creator tenant role. |
Project roles define the actions that a user or a group can perform inside a testing project, such as create manual test cases, or execute tests.
The table below shows the available project roles and their permissions.
Privileges | Project owner | Test Manager | Test Designer | Test Executor | Manual Tester | Read Only |
| Update, and delete projects (Read, Edit, Delete) |
| Create projects | ||||||
View projects (Read) | ||||||
Access to project settings |
Assign requirements to test cases |
Create, update and delete label |
| Re-execute test executions | ||||||
| Create custom user roles |
To manage users and groups, you need to enable access management in your Test Manager project. Open Test Manager and navigate to Project Settings > Manage access, open a project, click Enable now, and then confirm your action. Now you can start assigning users and groups to your organization's projects.
Assign Users and Groups
- Assign tenant-specific roles to users and groups.
- Assign users and groups to testing projects.
- Assign project-specific roles to users and groups.
Assigning tenant roles to users and groups
To manage the actions that a user or group can perform at a tenant level in terms of testing projects, you can assign tenant-specific roles to a user or group.
- Open Test Manager.
- Select Settings in the header.
- Go to the Role Assignments tab.
- Select Assign users/groups.
- Enter a user or group in the form field. For example, you can assign roles to the Everyone group.
- Select the tenant user roles that you want to assign. You can choose
- Project Creator
- Administrator
- Select Add to confirm your
action.
The tenant roles are now assigned to the users and groups.
Assigning users and groups to projects
To grant users and groups read-only access to a project, you can assign them to a project, without assigning other project-specific roles to users and groups.
- Open rTest Manager.
- Open a project.
- Navigate to Project Settings > Manage Access.
- Enter a user or group in the form field. For example, you can assign access to the Everyone group.
- Press Enter to add the user/group. You can add multiple users and groups at once.
- Click Add to confirm your
action. The users and groups are assigned to the project.
Assigning project roles to users and groups
To manage the actions that a user or group can perform inside a testing project, you can assign project-specific roles to users and groups. Visit User and Group Access Management to see the permissions for each project role.
- Open a project.
- Select the user roles that you want to assign.
action.
The selected roles are assigned to the specified users and groups.
Transfer Project Ownership
As Project owner, you can transfer this role to another user. The new user can grant Test Manager access to users and groups, and perform administrative tasks.
- Open a project.
- Find the user to which you want to transfer project ownership and click the vertical ellipsis.
- Select Transfer ownership in the dropdown list.
- Confirm your action. Project ownership is now transferred to the new user.
Edit Individual User and Groups
You can edit roles or remove users and groups.
To perform a bulk operation, see Removing users and groups.
Related articles
Behavior of unlicensed users
- Open the project.
- Review and navigate through test
objects, such as:
- Requirements
- Test Cases
- Test Sets
- Go to the Execution tab
and view the list of grouped executions by Test Set.
Note: Users who don't have a Tester - Named User license cannot open a test execution and view its details.
Creating custom roles
Editing custom roles
- Select Settings in the Test Manager header.
In the Manage roles tab, select
for the user role that you
want to edit, and then select one of the following actions:
- Edit role - This opens the Edit role panel and you can edit the name, description and permissions.
- Clone - This opens the Clone role panel and you can edit the clone of the role that you're creating.
- Select Save to record your changes.
