test-suite
Test Suite User Guide
Last updated Apr 15, 2025
Managing devices
Manage your devices individually by configuring settings or running applications.
To configure devices see:
Device Capabilities
  • Android and iOS support.
  • Run multiple devices at the same time.
  • Access any type of content except for videos.
Navigation in MDM Devices Panel
You can filter your devices using one or all of the following criteria:
  • By device type: Click the Androidor the Apple button.
  • By platform version: Click the Platform Version button and choose from the dropdown. By default is set to All.
You can reorder your devices by dragging and dropping a device card in a new position in the list.
Managing Devices in MDM
The following table lists the actions that you can take to manage your devices.
Action
Procedure
Edit
Configure device settings.
  1. In MDM, go to Devices
  2. Select a device from the list.
  3. Click Edit and configure your device settings.
  4. Click Save & Close to save changes.
Clone
Create a device clone.
  3. Click Clone and configure your device settings.
Delete
Delete the selected device.
  3. Click Delete, followed by Ok to confirm changes.
Start an application on this device
Choose and run an application on the selected device.
  3. Click Start an application to run on this device and choose an application from the dropdown.
  4. Click Connect to fire up the device.
    For more information, see Device Interaction.
  • Device Capabilities
  • Navigation in MDM Devices Panel
  • Managing Devices in MDM
