studio
2025.10
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-005 - Hardcoded Activity Properties
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Troubleshooting
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Studio User Guide
Last updated Dec 12, 2025
In this tutorial, you can learn how to incorporate a coded
automation called
CodedResetAssetValue.cs into a low-code workflow. The
CodedResetAssetValue.cs automation performs the following steps:
- Retrieves the current value of a specific asset from Orchestrator.
- Compares the retrieved asset value with the input value provided as an argument.
- If the previous asset value does not match the input value, it updates the asset value in Orchestrator.
- Logs messages that indicate the status of the asset value, whether it was updated or remained unchanged.
To use a coded automation inside a low-code workflow,
first create the coded workflow, then invoke it in the low-code workflow using the
Invoke Workflow File activity. Perform the following steps to incorporate a
coded automation within a low-code workflow:
