Process Mining
TemplateOne-SingleFile input fields
Introduction​
If your data for cases and events is available in one input file, you use the TemplateOne-SingleFile app template.
If you want to create a new TemplateOne process app, you must upload a dataset that contains the data to be used in the TemplateOne.
This must be a .tsv (tab-separated) file or .csv (comma-separated) file that contains a column for each input field.
Important:
Table names and field names are case-sensitive. Always make sure that the field names (column headers) in your dataset match the field names in the table below and that the file name is Event_log.
If you are extracting the data using CData Sync, _raw has to be added to the table names listed below, e.g. Event_log_raw.
Tutorial​
When creating your first dataset, check this video below for a tutorial. Use this to better understand how to create a dataset and use it in a TemplateOne process app.
Mandatory and optional fields​
Your input data file can have different fields or different field names. However, there are some fields mandatory for TemplateOne - SingleFile, which means that the data must be available in your input data file for a correct working of TemplateOne.
Note:
When a field is mandatory, it should not contain NULL values.
Field types​
Below is an overview of the different field types and their default format settings.
Field typeFormat
booleantrue, false, 1, 0
datetimeyyyy-mm-dd hh:mm:ss[.ms], where [.ms] is optional.
doubleDecimal separator: . (dot)
Thousand separator: none
textN/A
integerThousand separator: none
This page contains an overview of the input fields for TemplateOne - Single File. For each field, the name, the data type, and a short description are displayed. Apart from that, it is indicated whether the field is mandatory.
Event_log​
Below is an overview of the input fields for TemplateOne.
NameData typeMandatory Y/NDescription
activitytextYThe name of the event. This describes the step in the process.
case_idtextYThe unique identifier of the case the event belongs to.
event_enddatetimeYThe timestamp associated with the end of executing the event.
automatedbooleanNIndicates whether the event is manually executed or automated.
casetextNA user-friendly name to identify the case.
case_statustextNThe status of the case in the process. For example, open, closed, pending, approved, etc.
case_typetextNThe categorization of the cases.
case_valuedoubleNA monetary value related to the case.
event_costdoubleNThe costs for executing the event.
event_detailtextNInformation related to the event.
event_startdatetimeNThe timestamp associated with the start of executing the event.
teamtextNThe team that executed the event.
usertextNThe user who executed the event.
Custom fields​
Additionally, custom case and event fields for both case and event properties are available for TemplateOne.
  • 30 fields of type text;
  • 10 fields of type double;
  • 10 fields of type datetime;
  • 10 fields of type boolean;
  • 15 fields of type duration.
Custom fields have generic names. Below is an overview of the custom fields that can be used in a process app.
custom_case_text_{1...30}textN
custom_case_number_{1...10}doubleN
custom_case_datetime_{1...10}datetimeN
custom_case_boolean_{1...10}booleanN
custom_event_text_{1...30}textN
custom_event_number_{1...10}doubleN
custom_event_datetime_{1...10}datetimeN
custom_event_boolean_{1...10}booleanN
custom_event_duration_{1...5}integerN
When you use a custom field, you should rename the field in using Data manager to a name that matches the value. See Fields.
Custom fields that are empty in your dataset, are not displayed in Process Mining.
  • Introduction​
  • Tutorial​
  • Mandatory and optional fields​
  • Field types​
  • Event_log​
  • Custom fields​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
