Process Mining
Last updated Nov 6, 2025
System requirements
Introduction
Using DataBridgeAgent requires a UiPath Process Mining server installation. This page gives an overview of the system requirements for the Process Mining server on which you want to use DataBridgeAgent to load data for Process Mining.
Important:
If you want to install UiPath Process Mining or any of its components, you need access to an environment, and you need a UiPath Process Mining license. Please consult your UiPath Process Mining contact.
DataBridgeAgent does not require a separate license.
Server OS
Process Mining is a 64-bit program and requires a 64-bit environment. For production systems the following operating systems are supported:
  • Windows 10
  • Windows Server 2019
  • Windows Server 2016
  • Windows Server 2012 R2
Note: For an installation that is solely used for loading data with DataBridgeAgent to Process Mining Windows 10 suffices.
Minimum Ssystem requirements
Below is an overview of the minimum system requirements:
Component
Minimal size
CPU
1 core
Strong single-core performance is recommended.
Memory
32 GB
Storage
variable
The disk needs to be large enough for the operating system, UiPath Process Mining, the data, and cache files. DataBridgeAgent uses less than 1GB.
Note: The requirements only apply to a Process Mining server that is solely used for loading data with DataBridgeAgent to Process Mining. See Hardware and software requirements for a complete overview of the requirements for a Process Mining on-premises installation.
  • Introduction
  • Server OS
  • Minimum Ssystem requirements
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
