- Release notes
- Before you begin
- Managing access
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Process simulation
- Root cause analysis
- Simulating automation potential
- Starting a Task Mining project from Process Mining
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Autopilot™ for SQL (preview)
- Tips for writing SQL
- Exporting and importing transformations
- Viewing the data run logs
- Merging event logs
- Configuring Tags
- Configuring Due dates
- Configuring fields for Automation potential
- Activity Configuration: Defining activity order
- Making the transformations available in dashboards
- Data models
- Adding and editing processes
- Customizing process apps
- Publishing process apps
- App templates
- Notifications
- Additional resources
Process Mining
Different UiPath® products work together to discover, investigate and build automation and communicate process improvements. Automation Hub is used to turn ideas for automation that are discovered from Process Mining into real automated implementations. You can submit ideas for process improvements that are subject for automation directly from the process graph to Automation Hub.
In Automation Hub the idea will be investigated and processed. Once the automation is built, the impact should become visible in Process Mining.
When you identify a bottleneck in your process while monitoring, for example when a manual activity takes a long time to be executed, you might want to submit a request to automate the activity to Automation Hub. You can do this directly from the process graph.
Follow these steps to submit a request for automation and send it to Automation Hub.
When you hover your mouse over an activity in the process graph, the icon is displayed in the activity. When you select on the icon, the Submit to Automation Hub form is displayed at the right and the activity is selected by default.
The Submit to Automation Hub option is also available from the context menu of an Activity.
