orchestrator
2020.10
- Getting Started
- Requirements
- Best Practices
- Updating
- Identity Server
- High Availability Add-on
OUT OF SUPPORT
Orchestrator Installation Guide
Last updated Dec 12, 2023
After you have installed all nodes of your HAA cluster, setup the email server for alerts as follows:
Configure Alerts at Cluster Level
Configure Alerts at Database Level
Note: Throughput is higher than and Throughput is lower than options should be monitored but are dependent on usage. Baseline should be set on a normal usage scenario.
To monitor the High Availability Add-on, use the Prometheus built-in exporter on port
8070 with the Grafana Dashboard. Please see here for more details.
