Last updated Oct 8, 2025
Downloading the installation packages
You must install the following software on your management machine. Management machine refers to the machine you use to operate your cluster and that can access your cluster via the kubeconfig file. Your management machine can run Linux, Windows, or MacOS.
The following tools are required to successfully run the prerequisite checks, installation, and post-installation steps on your cluster via the client machine.
Tool
Download
uipathctl
Required. uipathctl is a UiPath® command-line tool that allows you to run commands against Automation Suite Kubernetes.
You can use uipathctl to check prerequisites in your environment, install Automation Suite, configure and manage it from a single unified CLI. For more information, including a complete list of uipathctl operations, see the uipathctl Reference Guide.
versions.json
Required. Needed to perform prerequisite checks and installation steps.
ocOptional. Ensure that oc matches the version of your cluster.
as-cmk.tar.gz
as-cmk.tar.gz contains the container images and deployment manifests of UiPath® shared capabilities and UiPath® products.
Download as-cmk.tar.gz
openshift.tar.gz
openshift.tar.gz contains the container images and deployment manifests of UiPath® shared capabilities and UiPath® products.
mirror-registry.sh
mirror-registry.sh is required to configure an external Docker registry.
Download mirror-registry.sh
hydrate-registry.sh
hydrate-registry.sh is required for configuring your external OCI-compliant registry for offline installations.
Download hydrate-registry.sh
as-images.txt
as-images.txt contains the name and version of the container images that you must pull and upload into the external Docker registry.
Download as-images.txt
as-helm-charts.txt
as-helm-charts.txt contain the details for the UiPath® application helm chart that you must pull and upload to an external Docker registry hosted on your environment.
Download as-helm-charts.txt
uipathtools
uipathtools is a CLI tool that contains a subset of uipathctl capabilities specific to health commands.
Download uipathtools
This page provides a list of download links for all the artifacts you may need to install or configure Automation Suite. Make sure to select the version of the artifacts you target.
uipathctl
Required. uipathctl is a UiPath® command-line tool that allows you to run commands against Automation Suite. You can use uipathctl to check prerequisites in your environment, install Automation Suite, configure and manage it from a single unified CLI.
Note:
Currently, uipathctl is only compatible with the x86 architecture. You cannot run uipathctl on machines based on the ARM architecture, such as Macs with Apple Silicon (M series) CPUs.
2024.10.5
To download uipathctl for Automation Suite 2024.10.5, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-darwin-amd64.tar.gz
2024.10.4
To download uipathctl for Automation Suite 2024.10.4, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-darwin-amd64.tar.gz
2024.10.3
To download uipathctl for Automation Suite 2024.10.3, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-darwin-amd64.tar.gz
2024.10.2
To download uipathctl for Automation Suite 2024.10.2, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-darwin-amd64.tar.gz
2024.10.1
To download uipathctl for Automation Suite 2024.10.1, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-darwin-amd64.tar.gz
2024.10.0
To download uipathctl for Automation Suite 2024.10.0, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-darwin-amd64.tar.gz
versions.json
2024.10.5
To download versions.json for Automation Suite 2024.10.5, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.5/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.5/versions.json
2024.10.4
To download versions.json for Automation Suite 2024.10.4, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.4/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.4/versions.json
2024.10.3
To download versions.json for Automation Suite 2024.10.3, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.3/versions.json
2024.10.2
To download versions.json for Automation Suite 2024.10.2, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.2/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.2/versions.json
2024.10.1
To download versions.json for Automation Suite 2024.10.1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.1/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.1/versions.json
2024.10.0
To download versions.json for Automation Suite 2024.10.0, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.0/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2024.10.0/versions.json
Openshift CLI (oc)
Optional. Make sure that oc matches the version of your cluster.
To download oc, see the OpenShift documentation.
UiPath.OrganizationMigrationApp
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To check which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
2024.10.4
  • Linux
    To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command:
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.4-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.4-linux.zip
  • Windows
    To download UiPath.OrganizationMigrationApp on a Windows machine, access this link.
2024.10.3
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.3-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.3-linux.zip
  • Windows
2024.10.2
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.2-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.2-linux.zip
  • Windows
2024.10.1
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.1-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.1-linux.zip
  • Windows
2024.10.0
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.0-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.0-linux.zip
  • Windows
as-cmk.tar.gz
Important:
Starting with Automation Suite 2024.10.2, we have replaced as-cmk.tar.gz with openshift.tar.gz.
However, Automation Suite versions 2024.10.0 and 2024.10.1 still use as-cmk.tar.gz.
as-cmk.tar.gz contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product.
as-cmk.tar.gz is required during installation and upgrade.
2024.10.1
For the checksum file, access this link.
  • Linux:
    To download as-cmk.tar.gz on a Linux machine, run the following command:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-cmk-2024.10.1.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-cmk-2024.10.1.tar.gz
  • Windows:
    To download as-cmk.tar.gz, access this link and rename the file to as-cmk.tar.gz.
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gzhttps://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-cmk-2024.10.0.tar.gz
  • Windows:
openshift.tar.gz
Note:
Starting with Automation Suite 2024.10.2, openshift.tar.gz replaces the as-cmk.tar.gz image used in previous versions.
openshift.tar.gz contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product.
openshift.tar.gz is required during installation and upgrade.
2024.10.5
  • Linux:
    To download openshift.tar.gz on a Linux machine, run the following command:
    wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.5/openshift-2024.10.5.tar.gzwget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.5/openshift-2024.10.5.tar.gz
  • Windows:
    To download openshift.tar.gz, access this link and rename the file to openshift.tar.gz.
2024.10.4
  • Linux:
    wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.4/openshift-2024.10.4.tar.gzwget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.4/openshift-2024.10.4.tar.gz
  • Windows:
2024.10.3
  • Linux:
    wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.3/openshift-2024.10.3.tar.gzwget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.3/openshift-2024.10.3.tar.gz
  • Windows:
2024.10.2
  • Linux:
    wget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.2/openshift-2024.10.2.tar.gzwget -O ~/openshift.tar.gz https://download.uipath.com/automation-suite/2024.10.2/openshift-2024.10.2.tar.gz
  • Windows:
mirror-registry.sh
2024.10.5
  • Linux:
    To download mirror-registry.sh on a Linux machine, run the following command:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.5/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.5/mirror-registry.sh
  • Windows:
    To download mirror-registry.sh on a Windows machine, access this link.
2024.10.4
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.4/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.4/mirror-registry.sh
  • Windows:
2024.10.3
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3/mirror-registry.sh
  • Windows:
2024.10.2
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2/mirror-registry.sh
  • Windows:
2024.10.1
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.1/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.1/mirror-registry.sh
  • Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.shhttps://download.uipath.com/automation-suite/2024.10.0/mirror-registry.sh
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.sh
  • Windows:
hydrate-registry.sh
hydrate-registry.sh is required for configuring your external OCI-compliant registry for offline installations in the Automation Suite.
2024.10.5
  • Linux:
    To download hydrate-registry.sh on a Linux machine, run the following command:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.5/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.5/hydrate-registry.sh
  • Windows:
    To download hydrate-registry.sh on a Windows machine, access this link.
2024.10.4
  • Linux:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.4/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.4/hydrate-registry.sh
  • Windows:
2024.10.3
  • Linux:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3/hydrate-registry.sh
  • Windows:
2024.10.2
  • Linux:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2/hydrate-registry.sh
  • Windows:
2024.10.1
  • Linux:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.1/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.1/hydrate-registry.sh
  • Windows:
2024.10.0
  • Linux:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.0/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.0/hydrate-registry.sh
  • Windows:
as-images.txt
as-images.txt contains the name and version of the container images that must be pulled and uploaded into the external Docker registry.
2024.10.5
  • Linux
    To download openshift-images.txt on a Linux machine, run the following command:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.5/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.5/openshift-images.txt
  • Windows:
    To download openshift-images.txt on a Windows machine, access this link and rename the file to as-images.txt.
2024.10.4
  • Linux
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.4/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.4/openshift-images.txt
  • Windows:
2024.10.3
  • Linux
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.3/openshift-images.txt
  • Windows:
2024.10.2
  • Linux
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.2/openshift-images.txt
  • Windows:
2024.10.1
  • Linux
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.1/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.1/openshift-images.txt
  • Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/openshift-images.txthttps://download.uipath.com/automation-suite/2024.10.0/openshift-images.txt
  • Linux
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.0/openshift-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2024.10.0/openshift-images.txt
  • Windows:
as-helm-charts.txt
as-helm-charts.txt contain the details for the UiPath® application helm chart that must be pulled and uploaded to an external Docker registry hosted on your environment.
2024.10.5
  • Linux:
    To download embedded-helm-charts.txt on a Linux machine, run the following command:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.5/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.5/embedded-helm-charts.txt
  • Windows:
    To download embedded-helm-charts.txt on a Windows machine, access this link and rename the file to as-helm-charts.txt.
2024.10.4
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-helm-charts.txt
  • Windows:
2024.10.3
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-helm-charts.txt
  • Windows:
2024.10.2
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-helm-charts.txt
  • Windows:
2024.10.1
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-helm-charts.txt
  • Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txthttps://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txt
  • Windows:
uipathtools
uipathtools is a CLI tool that contains a subset of uipathctl capabilities specific to health commands. The tool is backward compatible and works with any supported Automation Suite version. We recommend using uipathtools as the first step if you face any issue.
2024.10.5
To download uipathtools, run one of the following commands, depending on your OS:
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-darwin-amd64.tar.gz
2024.10.4
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-darwin-amd64.tar.gz
2024.10.3
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-darwin-amd64.tar.gz
2024.10.2
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-darwin-amd64.tar.gz
2024.10.1
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-darwin-amd64.tar.gz
2024.10.0
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-darwin-amd64.tar.gz
