Last updated Nov 13, 2025
Configuring Orchestrator parameters
Manifest configuration
Follow these steps to edit the Orchestrator manifest configuration:
  1. Edit the input.json file
    For details, see Configuring input.json.
  2. Add or edit the desired settings in the orchestrator section.
  3. Run this command:
    uipathctl manifest apply input.json --versions versions.json --kubeconfig kubeconfig.yaml --only orchestratoruipathctl manifest apply input.json --versions versions.json --kubeconfig kubeconfig.yaml --only orchestrator
Custom Orchestrator configuration
You can use this command to edit the Orchestrator custom configuration for both appSettings and NLog:
uipathctl config orchestratoruipathctl config orchestrator
Custom Orchestrator scenarios
You can modify various Orchestrator parameters using uipathctl. This enables the following configuration scenarios:
  • Manifest configuration
  • Custom Orchestrator configuration
  • Custom Orchestrator scenarios
