- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
- Get Audit Logs
- Download Audit Logs
Automation Suite API guide
Last updated Feb 24, 2025
Gets the audit logs for an organization, based on the organization name.
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'|
Query param |
Data type |
Description |
(optional) |
string |
Specify the available display language, in the shorten form. For example,
en, fr, de, ja etc.
(optional) |
int32 |
Display the top N entries of the audit. |
(optional) |
int32 |
Skip the top N audit entries from displaying. |
(optional) |
string |
Specify the DTO property used to sort audit entries by. For example,
createdOn, category, email, etc.
(optional) |
string |
Specify the sorting order. For example, ascending (
asc) or descending (desc).
(optional) |
string |
Specify the API version you are using. |
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is:https://{yourDomain}/{organizationName} -
Your
{access_token}is:1234(for length considerations). -
You set the following query params:
language=en -
top= 2, to display the top two entries -
skip= 2, to skip the first two entries -
sortBy=createdOn, to sort the entries by their creation time -
sortOrder=asc, to sort the entries from the earliest entry to the latest one
The call should resemble the following example (cURL):
curl --location --request GET ' https://{yourDomain}/{organizationName}/audit_/api/auditlogs/?language=en&top=2&skip=2&sortBy=createdOn&sortOrder=asc' \
--header 'Content-Type: application/json'curl --location --request GET ' https://{yourDomain}/{organizationName}/audit_/api/auditlogs/?language=en&top=2&skip=2&sortBy=createdOn&sortOrder=asc' \
--header 'Content-Type: application/json'Here's the response body for a successful audit entries retrieval:
"totalCount": 29,
"results": [
"createdOn": "2021-10-14T13:10:15.1964174+00:00",
"category": "User",
"action": "Login",
"auditLogDetails": "{\r\n \"userName\": \"System Administrator admin\",\r\n \"email\": \"\"\r\n}",
"userName": "System Administrator",
"email": "",
"message": "User 'System Administrator admin' logged in",
"detailsVersion": "1.0",
"source": "Cis"
"createdOn": "2021-10-14T12:41:00.3268964+00:00",
"category": "User",
"action": "Login",
"email": "",
"source": "Cis"
"totalCount": 29,
"results": [
"category": "User",
"action": "Login",
"email": "",
"source": "Cis"
"category": "User",
"action": "Login",
"email": "",
"source": "Cis"
