  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Automation Suite API guide
Last updated Feb 24, 2025
Allocate Licenses to an Organization
As a host admin, you can use endpoint to allocate licenses to an organization, based on the organization ID.
Important: To allocate licenses to organizations and tenants, you need to authenticate using the host credentials.
API Endpoint
PUT https://{yourDomain}/lrm/api/host/{hostAccountID}/organization/{organizationId}/license
Request Headers
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
Note: To obtain the {access_token}, make sure to authenticate through the ROPC method described here.
Path Parameters
Path param
Data type
hostAccountID
(required)
String
The ID of the host account that allocates the licenses.
Warning:
Always use the default value: feb0dd79-85b6-483b-b297-0e49a1aa5b7d
organizationId
(required)
String
The ID of the organization you want to allocate licenses to.
Request Body
The request body contains the array of license codes for various products and their corresponding quantity.
    "productQuantities":
          { "code": "string", "quantity": 0 }
Note:
  • To see the available license codes you may use in the request body, check out License codes.
  • You may allocate as many licenses as the organization has purchased.
Responses
200 OK
Returns the allocated licenses.
404
The host license does not exist or the feature flag for on-premise flows is off.
409
The license allocation is not allowed because it exceeds the host license quantities.
Example Request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://tom-jones-server.com
  • Your {access_token} is: 1234 (for length considerations).
  • Your {hostAccountId} is: j0ne5
  • The {organizationId} that needs license allocation is: y-y-y-delilah
  • You want to allocate product licenses to the organization as follows:
The call should resemble the following example (cURL):
curl --location --request POST 'https://tom-jones-server.com/lrm/api/host/j0ne5/organization/y-y-y-delilah/license' \
--header 'Content-Type: application/json' \
--data-raw '{
          { "code": "UNATT", "quantity": 2 },
          { "code": "AIG", "quantity": 1 },
          { "code": "TAUNATT", "quantity": 3 }
}'curl --location --request POST 'https://tom-jones-server.com/lrm/api/host/j0ne5/organization/y-y-y-delilah/license' \
--data-raw '{
Here's the response body for a successful license allocation:
  "accountId": "y-y-y-delilah",
  "bundleCode": "string",
  "endDate": 0,
  "gracePeriod": 0,
  "licenseCode": "string",
  "licenseStatus": "string",
  "products": [
      "code": "string",
      "quantity": 0,
      "type": "string",
      "features": [
          "code": "string",
          "type": "string",
          "value": "string"
  "templates": [
      "productCode": "string",
      "products": [
          "code": "string",
          "type": "string"
  "startDate": 0,
  "subscriptionCode": "string",
  "subscriptionPlan": "string",
  "payload": "string",
  "type": "string",
  "parentLicenseCode": "string"
  "endDate": 0,
  "gracePeriod": 0,
  "products": [
      "code": "string",
      "quantity": 0,
      "type": "string",
      "features": [
          "code": "string",
          "type": "string",
          "value": "string"
  "templates": [
      "products": [
          "code": "string",
          "type": "string"
  "startDate": 0,
  "type": "string",
  • API Endpoint
  • Request Headers
  • Path Parameters
  • Request Body
  • Responses
  • 200 OK
  • 404
  • 409
  • Example Request
