- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
2023.10.2+patch4
Release date: May 21, 2025
This release applies a patch to Automation Suite 2023.10.2. The patch addresses a cache validation issue that was preventing you from immediately receiving permissions when granted the App Creator role in Apps. With this patch, the issue has been fixed.
This fix will also be included in all future releases starting with Automation Suite 2023.10.9.
To apply this patch, follow the instructions in Applying a patch.
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
Component |
Version |
Istio | 1.20.0 |
ArgoCD | v2.7.7 |
Prometheus | v2.42.0 |
Grafana | 10.2.3 |
Fluentd & Fluent-bit |
logging-operator : 4.2.1 logging-operator-logging : 4.2.1 |
Gatekeeper | 3.12.0 |
Cert-Manager | v1.12.3 |
Velero | 3.1.6 |
