- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- Notifications- About notifications
- Managing notifications
- Logging
- Troubleshooting
Automation Suite admin guide
You can manage notifications for your organization in the Manage Notification view from the Notifications settings page.
Only Organization Admins can manage the notifications for a user group or organization.
- Access the external AD user group account in Outlook.
- Go to Group Settings, and then Edit Group.
- Select Let people outside the organization email the group.
Tips
- Users are not required to belong
                        to a group. When a notification is targeted directly to a user, their personal
                        preferences apply, unless overridden by a mandatory stetting, in which case the
                        Default group configuration is used. When a notification targets a
                        group:
                        - If the group unsubscribed from the event, the notification is not sent.
- If the group is subscribed to the event, the user's personal preferences apply, unless overriden, in which case the Default group configuration applies.
- If a user belongs to multiple groups, their final subscription is a union of all assigned group subscriptions.
You can view all the notifications that your organization received in the Notifications page. The Notifications page allows you to filter notifications, based on the service they notify you about, their severity, and the time when you received them.
To explore your organization's notifications:
- Open the Notifications panel.
- In the top-right, select the Notifications pageicon.
Filtering your organization's notifications
- Navigate to the Notifications page.
- Search for a keyword inside the Search bar.
- Select Service and filter notifications based on the service they notify about.
- Select Severity and filter notifications based on their severity.
- Select Timestamp and filter notifications based on the time they were sent.
Viewing only unread notifications
- Select Unread only in the top-right.
Unsubscribing from tenant or event
From the Notifications page you can unsubscribe from the event or tenant that a notification was received.
- Hover over a notification.
- Select Show more actions.
- Choose to unsubscribe from:
                        - The event that you're notified about.
- The tenant where the event took place.
Deleting notifications
To delete notifications select Show more actions and then Delete.
