studio-web
Studio Web user guide
  • Getting started
    • Overview
    • The Studio family
    • Frequently asked questions
    • Studio Web Configuration Checklist
  • Administration
    • Prerequisites for using Studio Web
    • Licensing
    • Managing access to Studio Web
    • System requirements
    • Governance
  • Designing automations
  • Running and testing your projects
  • Managing automations
Administrator requirements for enabling Studio Web in an Automation Suite organization, including licensing, robot, and configuration prerequisites.
Before Studio Web can be used in an organization, administrators must make sure that:
  • The organization is using named user licenses. If your organization is using the multiuser (concurrent) license model and you want to use Studio Web, contact UiPath® to switch to the named user model.
  • User license management is enabled for the organization (not applicable to the Community plan).
  • The following services are enabled for the tenant: Orchestrator, Integration Service.
  • Personal workspaces are enabled at user or group level.
  • Running personal automations is enabled at user or group level.
  • In the Orchestrator tenant settings, the option Automatically configure Serverless machines in Personal Workspace for Studio Web users is selected. If this setting is not selected or the serverless service is disabled on the tenant, users cannot run and publish projects.
  • The SignalR (Robots) scalability setting is enabled in the Orchestrator tenant settings.
  • Automation Suite Robots are enabled.
Note:
When a user opens Studio Web for the first time, Orchestrator's first-run provisioning enables that user's personal workspace. Because a personal workspace is recorded as an explicit per-user setting, this changes the user's access type from Inherited to Elevated in Configuring access for accounts, even when all roles still come from group provisioning. No group-provisioned roles or permissions are affected.
Connect
Stay updated
