studio-web
  • Getting started
    • Overview
    • The Studio family
    • Frequently asked questions
    • Studio Web Configuration Checklist
  • Administration
  • Designing automations
  • Running and testing your projects
  • Managing automations
    • Managing projects
    • Sharing and collaborating on projects
    • Creating a template from a project
    • Opening a project in Studio Desktop
Studio Web for Automation Suite User Guide
Last updated Jun 26, 2025
Automation details
The Automation details page contains detailed information about each project listed in the Automations page. To reach the Automation details page, simply select the icon on the right of a project.
Dedicated buttons on the top of the page allow you to edit and share the project. Select docs image See more to access more options for your project:
  • Project settings - Allows you to change the name and the description of the project. The window is resizable.
  • Change history - Opens the change history window, where you can see details about each version of the project listed in chronological order. Selecting a version opens it in Studio Web in read-only mode.
  • Duplicate - Creates a copy of the selected project.
  • Open in Studio Desktop - Opens the project in Studio Desktop. If Studio is not installed on your machine, a dialog is displayed giving you the option to download and install it.
  • Download - Downloads the selected project as a UIP file which can be imported in Studio Web.
  • Delete - Removes the selected project.
    Note: Deleting a project cannot be undone.
On the right side of the Automation details page, you can find other relevant project information:
  • Collaborators - Who collaborated on the project.
  • Connections used - What Integration Service connections are used in the project. Each connection contains the following information: an icon representing the connector, the connection name, the connection status, and whether a connection is personal or from a shared folder. The connection status is highlighted by the following icons:
    • The Connected docs image icon if the connection is valid.
    • The Disconnected docs image icon if there are issues with the connection. Select docs image > Fix connection on the right side of a disconnected connection to fix it. Please note that no status is available for browser connections. Select docs image > Manage all connection to handle your connections in the Integration Service
  • Project Details - See the project's published status and when it was created, last modified, and last deployed.
