studio-web
Studio Web user guide
For Each
Add a For Each activity to an API workflow in Studio Web to iterate over arrays and process each element, such as lists of users, orders, or records.
The For Each activity iterates over arrays and executes a defined set of steps for each array element. Use the For each activity to handle API responses containing object arrays, such as lists of users, orders, or records that require individual processing.
How to aggregate data in an array​
A common use case for the For Each activity is aggregating data from multiple API calls into a structured array using the Script activity.
The For Each activity automatically collects the output of the last activity within its Body flow, and compiles it into an array available in its own output.
Using the For Each activity​
To add a For each activity to your workflow:
  1. On your API workflow designer canvas, select the plus (+) icon. The Add activity menu appears.
  2. Select Loop, then ForEach.
  3. In the Properties panel, configure the following fields:
    • In—Use the Expression editor to specify the array for iteration. Usually, this array comes from a previous API response.
    • Item name—Assign a reference name for array elements (default is currentItem). Use this reference to access each item during iteration.
  4. In the Body of the ForEach loop, add the activities to process the array items.
  5. Add activities to the Then and Else branches as needed.
  6. Debug the workflow to execute the activity and generate output fields for later use.
For Each activity example​
The following example iterates over an array of employee objects, combines the first and last names of each employee, and returns the aggregated results in a structured response.
Open the Debug configuration window, then paste and save the following JSON syntax:
    "employees": [
            "first_name": "Bobbie",
            "last_name": "Draper",
            "position": "administration",
            "email": "[email protected]"
            "first_name": "James",
            "last_name": "Holden",
            "position": "manager",
    "employees": [
  1. On your API workflow designer canvas, add a For Each activity.
  2. Configure the For Each fields as follows:
    • In—Use the Expression editor to reference the employees array from the run configuration:
      $workflow.input.employees
  3. In the Body of the For Each loop, add a Script activity.
  4. For the Script activity, use Expression editor to create a JSON that combines the first_name and last_name properties into an object:
    return {
        "name": $currentItem.first_name + " " + $currentItem.last_name
    return {
  5. Save the configuration.
  6. At the end of the workflow, add a Response activity.
  7. Configure the response as follows:
    • Type—Success
    • Details—Open the Expression editor and write the following:
      $context.outputs.For_Each_2
      This step adds a validation at the beginning of the workflow to confirm a valid transaction exists before processing.
  8. Debug the workflow to execute the activity.
  9. Check the Output panel to review the response.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
