studio-web
Studio Web user guide
Container Layout
Use Container Layouts to create a complex app layout.
When a container layout control is added, a single container is available by default. To add more simple containers, click the "+" icon that border the existing containers.
To reposition a container within the layout, drag and drop the container to the desired position.
To resize containers, drag the container corner.
To delete a container, select it and use the Delete key on your keyboard. Alternatively, in the tree view, right-click the container and select Delete.
Note:
If you use the container layout as the root control in a page, when the page is opened as a pop-up, the container layout will automatically receive a minimum width of 300 pixels.
The container layout control has two sets of properties:
  • One set for the container layout
  • One set for every container within the layout
Note:
We recommend using Container Layout controls at a page level, for structuring the page into different sections. For aligning and positioning controls within a page, use Container controls.
Important:
For an easy maintenance and consistency between design time and runtime, avoid nesting container layouts.
Container Layout Properties
General
  • Hidden - If true, hides the control at runtime.
  • Disabled - If true, disables the control at runtime.
Events
No events.
Style
  • Background color - The background color of the layout.
  • Font - The font family for the container layout. All the containers within the layout share the same font family.
  • Margin- The margin of the layout. By default, a margin of 0px is set. Top/Bottom and Left/Right margin properties are combined. These properties can be detached using the Link button at the right side of the Margin section.
  • Padding - The padding of the layout. By default, a padding of 0px is set. Top/Bottom and Left/Right margin properties are combined. These properties can be detached using the Link button at the right side of the Padding section.
  • Size - The width and height of the layout. Be default, the Width is set to 100px, while the Height is set to auto, to allow the layout to expand based on the containers inside.
VB properties
VB propertyData typeDescription
HiddenBooleanIf true, hides the control at runtime.
DisabledBooleanIf true, disables the control at runtime.
  • Container Layout Properties
  • General
  • Events
  • Style
  • VB properties
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
