- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
To load the data and upload it to for use in Process Mining you must run the extract_theobald.ps1 file.
The time taken for this task will depend highly on the data volumes loaded.
Starting the file manually
Follow this step to start the data run.
- Run the
extract_theobald.ps1file to start the data run.Note:The
extract_theobald.ps1file is an unsigned script. If you cannot run the script because ofUnauthorizedAccess, signing the script may solve the issue. Refer to the official Microsoft documentation on Signing scripts for more information on how to sign the script to comply with the PowerShell execution policies.
The data run also creates a log file that can help in case of unexpected results or if the data upload with the data uploader fails. The file extraction.log contains the logs of the last data run. For each extraction that failed, a return code is displayed. Refer to the official Theobald Software documentation Call via Commandline for more information. When something with the setup is incorrect, this is mentioned in the error message.
Schedule a task for the data run
Instead of running the file manually, you can use Windows Task Scheduler to schedule a task that runs the batch script for automated data refreshes.
It is recommended to select the local SYSTEM user account for running the task and to select the Run with highest priority option in the Create Task window when creating the task in Windows Scheduler.
If you add an interval for which there is no data available, the dashboards will show an error message.
When the extraction is successful, data load may fail because of some faulty data being extracted. You can filter out this data should using Theobald Xtract Universal using the WHERE clause. Refer to the official Theobald documentation for more information on the WHERE Clause.
If you have a WHERE clause that uses variables (for example the extraction date) you cannot filter via the UI.
