Process Mining user guide
Deleting input tables
Delete an input table from a process app in Process Mining on Automation Suite, removing its data from the Input data list.
Note:
Deleting an input table removes the data for your process app. If you want to use the data in your process app at a later stage, you must re-upload the input table.
Follow these steps to delete an input table from the Input data list.
  1. Locate the input table you want to delete.
  2. Select the Remove table Remove table icon. A confirmation message is displayed.
  3. Select Delete to delete the input table.
Connect
Stay updated
