Process Mining
TemplateOne-SingleFile input fields
Introduction
If your data for cases and events is available in one input file, you use the TemplateOne-SingleFile app template.
If you want to create a new TemplateOne process app, you must upload a dataset that contains the data to be used in the TemplateOne.
This must be a .tsv (tab-separated) file or .csv (comma-separated) file that contains a column for each input field.
Important: Table names and field names are case-sensitive. Always make sure that the field names (column headers) in your dataset match the field names in the table below and that the file name is Event_log.
If you are extracting the data using CData Sync, `_raw` has to be added to the table names listed below, e.g. `Event_log_raw`.
Tutorial
When creating your first dataset, check this video below for a tutorial. Use this to better understand how to create a dataset and use it in a TemplateOne process app.
Mandatory and optional fields
Your input data file can have different fields or different field names. However, there are some fields mandatory for TemplateOne - SingleFile, which means that the data must be available in your input data file for a correct working of TemplateOne.
Note: When a field is mandatory, it should not contain NULL values.
Field types
Below is an overview of the different field types and their default format settings.
Field type
Format
boolean
true, false, 1, 0
datetime
yyyy-mm-dd hh:mm:ss[.ms], where [.ms] is optional.
double
Decimal separator: . (dot)
Thousand separator: none
text
N/A
integer
This page contains an overview of the input fields for TemplateOne - Single File. For each field, the name, the data type, and a short description are displayed. Apart from that, it is indicated whether the field is mandatory.
Event_log
Below is an overview of the input fields for TemplateOne.
Name
Data type
Mandatory Y/N
activity
text
Y
The name of the event. This describes the step in the process.
case_id
text
Y
The unique identifier of the case the event belongs to.
event_end
datetime
Y
The timestamp associated with the end of executing the event.
automated
boolean
N
Indicates whether the event is manually executed or automated.
case
text
N
A user-friendly name to identify the case.
case_status
text
N
The status of the case in the process. For example, open, closed, pending, approved, etc.
case_type
text
N
The categorization of the cases.
case_value
double
N
A monetary value related to the case.
event_cost
double
N
The costs for executing the event.
event_detail
text
N
Information related to the event.
event_start
datetime
N
The timestamp associated with the start of executing the event.
team
text
N
The team that executed the event.
user
text
N
The user who executed the event.
Custom fields
Additionally, custom case and event fields for both case and event properties are available for TemplateOne.
  • 30 fields of type text;
  • 10 fields of type double;
  • 10 fields of type datetime;
  • 10 fields of type boolean;
  • 15 fields of type duration.
Custom fields have generic names. Below is an overview of the custom fields that can be used in a process app.
Name
Data type
Mandatory Y/N
custom_case_text_{1...30}
text
N
custom_case_number_{1...10}
double
N
custom_case_datetime_{1...10}
datetime
N
custom_case_boolean_{1...10}
boolean
N
custom_event_text_{1...30}
text
N
custom_event_number_{1...10}
double
N
custom_event_datetime_{1...10}
datetime
N
custom_event_boolean_{1...10}
boolean
N
custom_event_duration_{1...5}
integerN
When you use a custom field, you should rename the field in using Data manager to a name that matches the value. See Fields.
Custom fields that are empty in your dataset, are not displayed in Process Mining.
  • Introduction
  • Tutorial
  • Mandatory and optional fields
  • Field types
  • Event_log
  • Custom fields
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
