- Release notes
- 2022.10.14
- 2022.10.13
- 2022.10.12
- 2022.10.6
- 2022.10.5
- 2022.10.4
- 2022.10.3
- 2022.10.2
- 2022.10.1
- 2022.10 (General Availability)
- Before you begin
- Getting started
- Managing access
- Working with process apps
- Creating process apps
- Loading data
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining
UiPath Process Mining is now also available in Automation Suite.
The UiPath deployment model called Automation Suite gathers the functionality from Automation Cloud and compresses it in a sole installation, allowing you to set up Process Mining and several other products in an on-premises or cloud-hosted environment. Learn more about Automation Suite.
With Process Mining you can discover, automate, and monitor your end-to-end business processes. It transforms data from your IT systems into visual interactive dashboards, allowing you to identify inefficiencies, bottlenecks, and non-conformance, as well as understanding the root-causes and possible risks. Process Mining enables all levels of the organization to understand business processes and to discover process improvement opportunities, including but not limited to Automation.
See Process Mining (Automation Suite) for an overview of the main features in Process Mining 2022.10 (Automation Suite).
With the release of Process Mining 2022.10 (Automation Suite), the Process Mining (Cloud) documentation (v0) is the default version of the Process Mining documentation. If you want to access a different version of the documentation, you can select a different version from the top navigation bar in the Documentation portal.
If you have bookmarked documentation pages from the Process Mining 2021.10 product guide, these links may be broken or direct you to a page in the Process Mining (Cloud) documentation.
A possible solution is to update the URL by adding the version number.
https:/docs.uipath.com/process-mining/docs/from-data-to-dashboard should become https:/docs.uipath.com/process-mining/v2021.10/docs/from-data-to-dashboard.
