- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Using the monitoring stack
- Alert runbooks
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
The monitoring stack for Automation Suite clusters includes Prometheus, Grafana, and Alertmanager, which are integrated within the Rancher Cluster Explorer UI.
Node failures might lead to a Kubernetes shutdown, which would disrupt Prometheus alerts. To prevent this, we recommend setting up a separate alert on the RKE2 server.
This page describes a series of monitoring scenarios. For more details, see the official Rancher documentation on using Rancher Monitoring.
When using collectors to export metrics to third-party tools, enabling application monitoring may disrupt the functionality of Automation Suite.
The monitoring stack for Automation Suite clusters includes Prometheus, Grafana, Alert Manager, and Longhorn Dashboard.
You can access the Automation Suite monitoring tools individually using the following URLs:
Application |
Tool |
URL |
Example |
Metrics |
Prometheus |
Dashboard |
Grafana |
Alert Management |
Alert Manager |
Persistent Block Storage |
Longhorn dashboard |
Monitoring tool authentication
To access the monitoring tools for the first time, log in as an admin with the following default credentials:
- Username: admin
- Password: to retrieve the password , run the following command:
kubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -dkubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -d
Dex authentication
To update the default password used for Dex authentication while accessing the monitoring tools, take the following steps.
Dex is a basic authentication method that is layered over the monitoring tools. Therefore, updating the Dex password does not impact the passwords for the monitoring tools. In this scenario, the passwords for the monitoring tools remain the same as before.
Run the following command by replacing
newpasswordwith your new password:password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]"password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]" -
<cluster_config.json>with the path to your configuration file:/opt/UiPathAutomationSuite/UiPath_Installer/install-uipath.sh -i <cluster_config.json> -f -o output.json --accept-license-agreement/opt/UiPathAutomationSuite/UiPath_Installer/install-uipath.sh -i <cluster_config.json> -f -o output.json --accept-license-agreement
https://monitoring.fqdn/metrics and select the Alerts tab. Here you can see all the alerts configured in Automation Suite.
To view the active alerts, filter the alert status by selecting the Firing checkbox and the Show annotations checkbox at the top. Here you can see all the alerts that are firing currently and their corresponding messages.
If alerts are too noisy, you can silence them. To do that, take the following steps:
Adding a new email configuration
To add a new email configuration after an installation, run the following command:
./uipathctl config alerts add-email \
--name test \
--to "[email protected]" \
--from "[email protected]" \
--smtp server.mycompany.com \
--username admin \
--password somesecret \
--require-tls \
--ca-file <path_to_ca_file> \
--cert-file <path_to_cert_file> \
--key-file <path_to_key_file> \
--send-resolved./uipathctl config alerts add-email \
--name test \
--username admin \
--require-tls \
--send-resolved|
Flag |
Description |
Example |
The name of the email configuration |
The email address of the receiver | |
The email address of the sender | |
SMTP server URL or IP address and port number |
Authentication username |
Authentication password |
Boolean flag to denote that TLS is enabled at the SMTP server. |
N/A |
File path containing the CA Certificate of the SMTP server. This is optional if the CA is private. |
File path containing the certificate of the SMTP server. This is optional if the certificate is private. |
File path containing the private key of the certificate of the SMTP server. This is required if the certificate is private. |
Boolean flag to send an email once the alert is resolved. |
N/A |
Removing an email configuration
To remove an email configuration, you must run the following command. Make sure to pass the name of the email configuration you want to remove.
./uipathctl config alerts remove-email --name test./uipathctl config alerts remove-email --name test Updating an email configuration
To update an email configuration, you must run the following command. Make sure to pass the name of the email configuration you want to update and the additional optional parameters you want to edit. These parameters are the same as the ones for adding a new email configuration. You can pass one or more flags at the same time.
./uipathctl config alerts update-email --name test [additional_flags]./uipathctl config alerts update-email --name test [additional_flags]To access Grafana dashboards, you must retrieve your credentials and use them to log in:
Username:
kubectl -n cattle-monitoring-system get secrets/rancher-monitoring-grafana -o "jsonpath={.data.admin-user}" | base64 -d; echokubectl -n cattle-monitoring-system get secrets/rancher-monitoring-grafana -o "jsonpath={.data.admin-user}" | base64 -d; echo -
Password:
kubectl -n cattle-monitoring-system get secrets/rancher-monitoring-grafana -o "jsonpath={.data.admin-password}" | base64 -d; echokubectl -n cattle-monitoring-system get secrets/rancher-monitoring-grafana -o "jsonpath={.data.admin-password}" | base64 -d; echo
You can monitor the Istio Service Mesh via the following Grafana dashboards: Istio Mesh and Istio Workload.
Istio Mesh dashboard
This dashboard shows the overall request volume, as well as 400 and 500 error rates across the entire service mesh, for the selected time period. The data is displayed in the upper-right corner of the window. See the 4 charts across the top for this information.
It also shows the immediate Success Rate over the past minute for each individual service. Note that a Success Rate of NaN indicates the service is not currently serving traffic.
Istio Workload dashboard
This dashboard shows the traffic metrics over the time range selected in the upper-right corner of the window.
Use the selectors at the top of the dashboard to drill into specific workloads. Of particular interest is the uipath namespace.
The top section shows overall metrics, the Inbound Workloads section separates out traffic based on origin, and the Outbound Services section separates out traffic based on destination.
You can monitor persistent volumes via the Kubernetes / Persistent Volumes dashboard. You can keep track of the free and used space for each volume.
You can also check the status of each volume by selecting the PersistentVolumes item within the Storage menu of the Cluster Explorer.
To check the hardware utilization per node, you can use the Nodes dashboard. Data on the CPU, Memory, Disk, and Network is available.
You can monitor the hardware utilization for specific workloads using the Kubernetes / Compute Resources / Namespace (Workloads) dashboard. Select the uipath namespace to get the needed data.
- Select the downwards pointing arrow next to the chart title, and then select Share.
- Select the Snapshot tab, and set the Snapshot name,Expire, and Timeout.
- Select Publish to snapshot.raintank.io.
For more details, see the Grafana documentation on sharing dashboards.
For details on how to create custom persisten Grafana dashboards, see Rancher documentation.
Admin access to Grafana is not typically needed in Automation Suite clusters as dashboards are available for read access by default to anonymous users, and creating custom persistent dashboards must be created using the Kubernetes-native instructions previously linked in this document.
Nonetheless, admin access to Grafana is possible with the following instructions.
The default username and password for Grafana admin access can be retrieved as follows:
kubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-user}' | base64 -d && echo
kubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-password}' | base64 -d && echokubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-user}' | base64 -d && echo
kubectl get secret -n cattle-monitoring-system rancher-monitoring-grafana -o jsonpath='{.data.admin-password}' | base64 -d && echoNote that in High Availability Automation Suite clusters, there are multiple Grafana pods in order to enable uninterrupted read access in case of node failure, as well as a higher volume of read queries. This is incompatible with admin access because the pods do not share session state and logging in requires it. In order to work around this, the number of Grafana replicas must be temporarily scaled to 1 while admin access is desired. See the instructions on how to scale the number of Grafana replicas:
# scale down
kubectl scale -n cattle-monitoring-system deployment/rancher-monitoring-grafana --replicas=1
# scale up
kubectl scale -n cattle-monitoring-system deployment/rancher-monitoring-grafana --replicas=2# scale down
# scale up
kubectl scale -n cattle-monitoring-system deployment/rancher-monitoring-grafana --replicas=2Documentation on the available metrics is here:
You can create custom alerts using a Prometheus query with a Boolean expression.
- To do so, select Prometheus Rules in the Advanced menu of the Monitoring Dashboard.
- Select Create in the upper-right corner of the window to create a new alert, and follow the Rancher documentation: PrometheusRules
- When the alert fires, it should show on the Monitoring Dashboard. Additionally, it will be routed to any of the configured receivers.
To see the status of pods, deployments, statefulsets, etc., you can use the Cluster Explorer UI. This is the same landing page as accessed after logging into the rancher-server endpoint. The homepage shows a summary, with drill downs into specific details for each resource type on the left. Note the namespace selector at the top of the page. This dashboard may also be replaced with the Lens tool.
Prometheus uses the Prometheus remote write feature to collect and export Prometheus metrics to an external system.
remote_write on an Automation Suite cluster:
- Accessing the monitoring tools
- Overview
- Monitoring tool authentication
- Dex authentication
- Checking currently firing alerts
- Silencing alerts
- Configuring the alerts
- Adding a new email configuration
- Removing an email configuration
- Updating an email configuration
- Accessing Grafana dashboard
- Monitoring the Service Mesh
- Istio Mesh dashboard
- Istio Workload dashboard
- Monitoring Persistent Volumes
- Monitoring hardware utilization
- Creating shareable visual snapshot of a Grafana chart
- Creating custom persistent Grafana dashboards
- Admin access to Grafana
- Querying Prometheus
- Creating custom alerts
- Monitoring Kubernetes resource status
- Exporting Prometheus metrics to an external system
