- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Managing products
- Switching to the secondary cluster
- Guidelines on upgrading an Active/Passive deployment
- Guidelines on backing up and restoring an Active/Passive deployment
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
You can convert an existing installation into multi-site by taking the following steps:
Convert the standalone Automation Suite cluster into the primary cluster. For details, see Converting a standalone cluster into a primary cluster.
Install secondary Automation Suite cluster. For details, see Disaster Recovery - Installing the secondary cluster.
To convert an existing Automation Suite cluster into aprimary cluster of the multi-site deployment, take the following steps:
Add or modify the required
cluster_config.jsonparameters on the first server node. For more details, see Advanced installation experience.{ "fabric": { "redis": { "ha": true, "license": "xyz" //base64 encoded redis license } }, "cluster_fqdn": "automationsuite-primary.mycompany.com", "multisite": { "enabled": true, "primary": true, "other_site_kubeconfig": xxx, //another cluster kubeconfig }, "fixed_rke_address": "automationsuite-primary.mycompany.com" }{ "fabric": { "redis": { "ha": true, "license": "xyz" //base64 encoded redis license } }, "cluster_fqdn": "automationsuite-primary.mycompany.com", "multisite": { "enabled": true, "primary": true, "other_site_kubeconfig": xxx, //another cluster kubeconfig }, "fixed_rke_address": "automationsuite-primary.mycompany.com" }Note:It is recommended to keep the FQDN of your existing Automation Suite setup to avoid reconfiguring all your robots.
Online
Configure the infrastructure on the first server node
Navigate to the installer folder:
cd /opt/UiPathAutomationSuite/{version}/installercd /opt/UiPathAutomationSuite/{version}/installer -
Run the following command on the first server node:
./install-uipath.sh -i cluster_config.json -o output.json -k --skip-compare-config --force-update-fqdn --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -k --skip-compare-config --force-update-fqdn --accept-license-agreement
Configuring the infrastructure on the remaining cluster nodes
Copy the
cluster_config.jsonfile from the first server node to all the other nodes. -
Run the following command on all the other nodes:
./install-uipath.sh -i cluster_config.json -o output.json -k -j <node_type> --skip-compare-config --force-update-fqdn --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -k -j <node_type> --skip-compare-config --force-update-fqdn --accept-license-agreementNote:Replace<node_type>with the appropriate node type:-
server– for other server nodes -
agent– for agent nodes -
task-mining– for Task Mining node -
gpu– for GPU node -
asrobots– for Automation Suite Robots node
Configuring the fabric and services on the first server node
To configure the fabric and services on the first server node, run the following command:
./install-uipath.sh -i cluster_config.json -o output.json -f -s --skip-compare-config --force-update-fqdn --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -f -s --skip-compare-config --force-update-fqdn --accept-license-agreementOffline
./install-uipath.sh -i cluster_config.json -o output.json -k --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /uipath/tmp --skip-compare-config --force-update-fqdn --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -k --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /uipath/tmp --skip-compare-config --force-update-fqdn --accept-license-agreement
Copy the
cluster_config.jsonfile from the first server nodes to all other nodes. -
./install-uipath.sh -i cluster_config.json -o output.json -k -j <node_type> --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -k -j <node_type> --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreementNote:Replace<node_type>with the appropriate node type:-
gpu– for GPU node -
./install-uipath.sh -i cluster_config.json -o output.json -f -s --install-type offline --skip-compare-config --force-update-fqdn --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -f -s --install-type offline --skip-compare-config --force-update-fqdn --accept-license-agreement
