uipathctl reference guide
Last updated Nov 11, 2025
uipathctl rke2 install
Install UiPath components.
uipathctl rke2 install [flags]uipathctl rke2 install [flags]
Options
--accept-license-agreement   Accept the license agreement
  -d, --debug                      Run in debug mode
  -h, --help                       help for install
  -i, --input string               Specify input json file
  -k, --install-kubernetes         Install Kubernetes and infrastructure modules
  -j, --join-node string           Type of node to be joined to an existing cluster
      --kubeconfig string          Specify path to the kubeconfig file
  -m, --machines string            Comma separated IP address / hostnames of all the machines
  -o, --output string              Specify output json file
      --region string              Specify region label value
  -r, --restore                    Setup Restore
      --skip-packages-install      Disable installation of package dependencies(helm, jq, etc.)
      --skip-pre-reqs              Skips pre-requisite checks during install
      --zone string                Specify zone label value      --accept-license-agreement   Accept the license agreement
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
