uipathctl reference guide
Last updated Nov 11, 2025
uipathctl rke2 update-fqdn
Update the FQDN.
uipathctl rke2 update-fqdn [flags]uipathctl rke2 update-fqdn [flags]
Options
--concurrency int   Number of nodes update concurrently (default 1)
  -h, --help              help for update-fqdn
  -i, --input string      Cluster configuration file
      --versions string   path to versions file      --concurrency int   Number of nodes update concurrently (default 1)
      --timeout duration    timeout of the command (default 5h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
