- Release notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Share Idea or Automation
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Automation Hub User Guide
Last updated Apr 15, 2025
After successfully logging in, you, as an RPA Sponsor, can check out the list of the and Components submitted within your tenant.
You are encouraged to Share your own ideas or components that will boost the company’s RPA assimilation as well as keep an eye on the tenant evolution through the Dashboards Overview module.
Within the Workspace Overview module, you can have a detailed view over:
- Your collaborations;
- Your components;
- The Automation Pipeline;
- The Ideas you follow.
- view the and choose to follow the ones that drow your attention,
- check out and download the components shared within your tenant,
- access the Leaderboard.
