Automation Hub User Guide
Last updated Apr 15, 2025
Enable From Automation Suite
Enabling Automation Store
To enable Automation Store on one of your Automation Suite tenants, use the steps below:
  1. In Automation Suite, go to Admin > Tenants, select the tenant where you wish to have Automation Store enabled, and click on the three dots next to it.
  2. Click on Edit services.
  3. Click on the Automation Store service from the Edit Services menu.
  4. Save your selection. Your tenant is now having Automation Store service enabled.
  5. You will see the Automation Store service next to the other services enabled on the selected tenant.
  • Enable From Automation Suite
  • Enabling Automation Store
