Automation Hub User Guide
Last updated Oct 17, 2024
Starting as a Technical Reviewer
After successfully logging in, you, as a Technical Reviewer need to focus on pushing forward automations by identifying code quality issues and approving automations for . To do this check the Automation Pipeline > Review page and review automations that are awaiting the technical review.
By accessing the Explore module you can:
  • Starting as a Technical Reviewer
