- Release Notes
- Getting Started
- Permissions
- Starting as
- Starting as the Account Owner
- Starting as an RPA Sponsor
- Starting as a Component Curator
- Starting as a Program Manager
- Starting as an Idea Approver
- Starting as an Authorized User
- Starting as a Standard User
- Starting as a Citizen Developer Self User
- Starting as a Citizen Developer Power User
- Starting as a Business Reviewer
- Starting as a Technical Reviewer
- Understanding the Citizen Developer Flow
- Learn More With Courses From Academy
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Automation Hub User Guide
After successfully logging in, you, as a Citizen Developer Power User can explore the list of submitted for your tenant and get inspired.
You are encouraged to share automations created for tasks or processes performed by you or your team. The automations you submit should be made for low risk, simple/medium task/activities or processes and are addressed to users from your own department or team.
Besides sharing automations you can perform the development for selected automations. To do this access the Automation Pipeline page > Implementation view > apply the Development Phase and Not Started Status filters and choose which automations you want to develop.
Within the Workspace module, you can have a detailed view over:
- Your automations;
- Your components;
- The Automations you follow.
By accessing the Explore module you can:
- view both the automations that are ready to use as well as the submitted automations and choose to follow or show your interest for the ones that draw your attention,
- check out and download the components submitted within your tenant.
