- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-005 - Hardcoded Activity Properties
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Troubleshooting
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Incorporate a coded automation into a low-code workflow in Studio using a step-by-step tutorial with an Orchestrator asset scenario.
In this tutorial, you can learn how to incorporate a coded automation called CodedResetAssetValue.cs into a low-code workflow. The CodedResetAssetValue.cs automation performs the following steps:
- Retrieves the current value of a specific asset from Orchestrator.
- Compares the retrieved asset value with the input value provided as an argument.
- If the previous asset value does not match the input value, it updates the asset value in Orchestrator.
- Logs messages that indicate the status of the asset value, whether it was updated or remained unchanged.
To use a coded automation inside a low-code workflow, first create the coded workflow, then invoke it in the low-code workflow using the Invoke Workflow File activity. Perform the following steps to incorporate a coded automation within a low-code workflow:
Create a new coded workflow. For this example, name it
CodedResetAssetValue.- Give the following return arguments to the
Executemethod to indicate if the asset value was changed and to provide the asset value:(bool assetValueWasChanged, string assetValue) - For the
Executemethod, add the following input parameters:assetName (string)andassetValue (string).public (bool assetValueWasChanged, string assetValue) Execute(string assetName, string assetValue)public (bool assetValueWasChanged, string assetValue) Execute(string assetName, string assetValue) - Use the
GetAssetcoded automation API to retrieve the current value of the specified asset using theassetNameparameter. - Store the previous asset value in the
previousAssetValuevariable .var previousAssetValue = system.GetAsset(assetName).ToString();var previousAssetValue = system.GetAsset(assetName).ToString(); - Compare the previous asset value with the input asset value using the
Equalsmethod. - If the values are equal, return
(false, assetValue)to indicate that the asset value was not changed. - If the values are different, use the
SetAssetcoded automation API to update the asset value to the inputassetValue. - Return
(true, previousAssetValue)to indicate that the asset value was changed, along with the previous asset value.
if (previousAssetValue.Equals(assetValue)) { return (assetValueWasChanged: false, assetValue: assetValue); } else { system.SetAsset(assetValue, assetName); return (assetValueWasChanged: true, assetValue: previousAssetValue); }if (previousAssetValue.Equals(assetValue)) { return (assetValueWasChanged: false, assetValue: assetValue); } else { system.SetAsset(assetValue, assetName); return (assetValueWasChanged: true, assetValue: previousAssetValue); } - Give the following return arguments to the
Create a low-code workflow. For this example, name it
WorkflowUsingCodedAutomation. -
Add an Assign activity and assign a value to the
assetValuevariable. -
Add an Invoke Workflow File activity and invoke the
CodedResetAssetValue.cscoded automation. Add the required arguments.Note:For Windows projects: In the Invoke Workflow File activity, select Browse for File and change the file extensions you're browsing for, from Workflow Files (
*.xaml,*.uiwf) to All Files (*.*). This allows you to view all files, including.cs. -
Add an If activity, and log messages for the scenarios where an asset value remains unchanged, and for the scenario where an asset value is updated.
