- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Submit a new entry
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Process Mining Integration
- Studio Integration
- Task Capture Integration
- Automation Hub - Automation Cloud Integration
- Automation Hub - Maestro integration
- Automation Store
- Additional Resources
Automation Hub User Guide
Last updated Apr 22, 2026
After successfully logging in, you, as a Technical Reviewer need to focus on pushing forward automations by identifying code quality issues and approving automations for . To do this check the Automation Pipeline > Review page and review automations that are awaiting the technical review.
- view both the automations that are ready to consume as well as the submitted automations and choose to follow or show your interest for the ones that draw your attention,
- check out and download the components submitted within your tenant.
