automation-cloud-public-sector
Automation Cloud Public Sector admin guide
Last updated Nov 11, 2025
Configuring the firewall
This page lists the domains used by Automation CloudTM Public Sector and our other cloud services. You can use this information to compile an allow list for UiPath® software in the configuration of your company's perimeter network.
In the event that your company restricts access to only allowed websites, you must allow accessing the necessary domains based on the UiPath products you use and the scenarios per product that you use. If you do not allow access to the required domains, Automation CloudTM Public Sector may not function as intended.
Important: If your organization or tenant migrates to a new region, you must also allow the outbound IP addresses for that region, otherwise you might experience loss of functionality for certain services.
Automation Cloud Public Sector Portal
The following table lists the domains used by Automation Cloud Public Sector Portal:
Scenario
Domains to Allow
UiPath Automation Cloud Public Sector
  • https://govcloud.uipath.us
  • https://govcloud.uipath.us/portal_/cloudrpa
  • https://govcloud.uipath.us/portal_/signinwithsso
  • https://govcloud.uipath.us/<accountname>/
  • https://govcloud.uipath.us/<accountname>/<tenantname>/portal
Login flows (configured via SSO)
  • https://login.microsoftonline.com
Sign in with Azure Active Directory (Azure AD)
  • https://aadcdn.msftauth.net
Sign in with UiPath Assistant (basic email)
  • *-signalr.service.signalr.net
For events related to signing in with basic authentication:
  • https://account.uipath.com
  • https://platform-cdn.uipath.com
Sign in with UiPath Studio (basic email)
  • https://api.nuget.org
  • https://gallery.uipath.com
  • https://pkgs.dev.azure.com
Static assets: Fonts, Styling and CDN hosted scripts
Fonts:
  • https://use.typekit.net
  • https://fonts.gstatic.com
Images:
  • https://s.gravatar.com
  • https://secure.gravatar.com
  • https://*.wp.com
  • https://*.googleusercontent.com
  • https://i.ytimg.com
CSS:
  • https://fonts.googleapis.com/css
  • https://p.typekit.net
  • https://staticresources.uipath.us
Scripts:
  • https://primer.typekit.net
Sign in via Auth0 (for EU)
  • uipath.eu.auth0.com
Update services
  • ctldl.windowsupdate.com
To configure network connections, use Microsoft documentation.
App Insights / Google Tag Manager
  • https://usgovvirginia-0.in.applicationinsights.azure.us
  • https://www.googletagmanager.com/gtm.js?id=GTM-PLLP8P
  • https://code.jquery.com/jquery-3.5.1.min.js
Important: If you use Azure buckets, they must not be located in the tenant's region or in the failover region.
Outbound IPs
To ensure proper functionality for UiPath services, we recommend allowing the following IPs:
  • 52.247.128.100
  • 52.227.65.197
  • 52.245.221.122
Action Center
The following table lists the domains used by Action Center that we recommend allowing, based on the functionality you plan to use:
Scenario
Domains to Allow
Navigate to Action Center page
  • https://govcloud.uipath.us/<accountName>/<tenantName>/actions_
  • https://govcloud.uipath.us/<accountName>/<tenantName>/processes_
  • https://govcloud.uipath.us/<accountName>/<tenantName>/bupproxyservice_
  • https://uipath-acc-pgov.uipath.us
Automation Cloud Robots - Serverless
Static IP configuration
Static IP for Cloud Robot - Serverless enables you to route outbound network traffic through a dedicated, static IP address range managed by UiPath. This allows you to whitelist or securely integrate with external systems that restrict incoming connections to known IPs.
Configuration
You can enable Static IP while creating the Serverless template and going to the Network Configuration page.
Availability
The Stable IP feature is available for Cloud Robot - Serverless in supported regions.
These static IP addresses can sometimes change as a result of infrastructure deployments. To help keep you on top of any changes, we have compiled a list of up-to-date static egress IPs, which you can check in the following tables.
Community Users
RegionCIDRIPs
Europe
20.191.43.0/30
20.191.42.240/30
20.191.43.0
20.191.43.1
20.191.43.2
20.191.43.3
20.191.42.240
20.191.42.241
20.191.42.242
20.191.42.243
Enterprise Users
RegionCIDRIPs
Australia
20.53.170.116/30
20.53.170.208/30
20.53.170.116
20.53.170.117
20.53.170.118
20.53.170.119
20.53.170.208
20.53.170.209
20.53.170.210
20.53.170.211
United States
20.102.5.168/30
20.102.0.76/30
20.102.5.168
20.102.5.169
20.102.5.170
20.102.5.171
20.102.0.76
20.102.0.77
20.102.0.78
20.102.0.79
Japan
20.44.188.168/30
20.44.185.192/30
20.44.188.168
20.44.188.169
20.44.188.170
20.44.188.171
20.44.185.192
20.44.185.193
20.44.185.194
20.44.185.195
Europe (European Union)
20.191.46.104/30
20.191.43.60/30
20.191.46.104
20.191.46.105
20.191.46.106
20.191.46.107
20.191.43.60
20.191.43.61
20.191.43.62
20.191.43.63
Automation Hub
The following table lists the domains used by Automation Hub:
ScenarioDomains to Allow
Navigate to the Automation Hub page
  • http://*.userpilot.io
  • https://dc.services.visualstudio.com
  • https://ah-prod-ts-blue-eu.uipath.com
  • https://ah-prod-ts-blue-us.uipath.com
  • https://ah-prod-ts-blue-ja.uipath.com
  • https://ah-prod-ts-blue-au.uipath.com
  • https://ah-prod-ts-blue-ca.uipath.com
  • https://ah-prod-ts-blue-sea.uipath.com
  • https://ah-prod-ts-blue-uk.uipath.com
  • https://ah-prod-ts-blue-in.uipath.com
  • https://ah-gxp-ts-blue-us.uipath.com
Use OpenAPI for Automation Hub
  • https://automation-hub.uipath.com
  • http://ah-gxp-openapi-us.uipath.com
Access Public Sector in Automation Hub
Automation Ops
The following table lists the domains used by Automation Ops:
Scenario
Domains to Allow
Navigate to the Automation Ops page
  • *-signalr.signalr.azure.us
Data Service
The following table lists the domains used by Data Service:
Scenario
Domains to Allow
All Data Service operations
Fetching static frontend content
  • https://staticds.uipath.us
Document Understanding
The following table lists the domains used by Document Understanding:
Module or ScenarioDomains to Allow
Network and Storagehttps://*.uipath.us
Telemetry and SignalRhttps://*.azure.us
Public endpointsCheck the Public endpoints page for the full list of public endpoints URLs.
Insights
The following table lists the domains used by Insights:
Scenario
Domains to Allow
Navigate to the Insights page
  • https://*.lookercdn.com
  • https://uipath-insights-statics.azureedge.net/
  • https://*.looker.uipath.com/
Static IPs
Static IPs allow you to add a list of IPs for the Log Export functionality to the allowlist and not open your network to all external IPs.
To ensure proper performance for the Log Export functionality, make sure to add the Outbound IPs from the Automation Cloud Public Sector Portal section to the allowlist.
Limitations
Due to a limitation on Microsoft side for Log Export, you cannot set up inbound IP restriction when your Azure blob storage account and the Insights infrastructure is under the same region in Azure. Because of this, you cannot use the USGov Virginia region for the blob storage account. For more information on this limitation, check the Restrictions for IP network rules page from the Microsoft Azure Blob Storage documentation.
Orchestrator
Robots send traffic to these Automation CloudTM Public Sector Orchestrator domains. We recommend that you allow them to ensure proper functioning of your automations, as described in the following table:
Module or Functionality
Domains to Allow
UiPath Orchestrator
  • https://orch-cdn.uipath.com
Automation CloudTM Public Sector Robots - VM
  • https://download.uipath.com
Storage
    If using Amazon s3 buckets:
    • *.s3.amazonaws.com
    Package and library feeds
    (library, tenant processes, and others)
    Azure SignalR
    • *.service.signalr.net
    Studio and Robot auto-update functionality
    Traffic Manager (internal)
    • *.trafficmanager.net
    Process Mining
    The following table lists the domains used by Process Mining:
    Identity Server
    Static assets
    • https://content.usage.uipath.com
    • https://i1.wp.com
    Azure SignalR
    • *.signalr.azure.us
    Telemetry
    • https://*.in.applicationinsights.azure.us
    Upload files
    • *.blob.core.usgovcloudapi.net
    Test Manager
    This page lists the domains used by Test Manager and the outbound IP addresses that you should consider allowing if you want to use various Test Manager capabilities.
    Domains
    The following table lists the domains used by Test Manager that we recommend allowing, based on the functionality you plan to use:
    Module or functionalityDomains to allow
    UiPath Test Manager
    Azure SignalR
