automation-cloud
Automation Cloud admin guide
Last updated Apr 23, 2026
Understanding authentication models
UiPath offerings support two authentication approaches: local accounts and directory accounts. Each approach defines how user identities are created, authenticated, and managed.
Depending on the cloud platform that you are using, refer to the following resources:
Local accounts
Local accounts are user accounts that are created and managed directly within a UiPath organization. Organization administrators invite users to join, and each user signs in by using the credentials associated with their account.
Local accounts provide a self-contained authentication approach and allow organizations to manage users without integrating an external identity provider. Local accounts can coexist with directory-based authentication, depending on the offering and configuration.
Directory accounts
Directory accounts rely on an external identity provider that integrates with the UiPath platform. User identities are created and maintained outside UiPath and are referenced by the platform only for authentication and authorization.
Directory-based authentication allows organizations to reuse existing identity systems, centralize account management, and apply corporate security policies consistently across applications. Supported directory integrations include Microsoft Entra ID and identity providers that support the SAML 2.0 standard.
Authentication and authorization
Authentication verifies a user’s identity. Authorization determines which services, tenants, and features the user can access.
In UiPath offerings, authentication is handled either by the UiPath platform or by an integrated identity provider, depending on the selected authentication model. Authorization is always enforced within UiPath through roles, groups, and licenses.
  • Local accounts
  • Directory accounts
  • Authentication and authorization
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
