Last updated Sep 10, 2025
Prerequisite checks
It is recommended to run prerequisite checks to ensure that you properly configured the cloud infrastructure and to validate input.json before starting the Automation Suite installation.
You can run a prerequisite check using the command. By default, this command verifies all the prerequisites. You can use the following flags:
  • --excluded, if you want to exclude components from the execution.
  • --verbose, if you want to access the detailed prerequisites check output. You can skip this flag for a more concise and simplified output.
The prerequisite and health checks/tests run in the <uipath> namespace. You must either grant the uipathctl tool the necessary permissions to allow the creation of the <uipath> namespace or create it yourself before running the checks/tests. Additionally, some checks/tests require that you enable the use of hostNetwork.
To run the tests related to the host network, you must allow the tool to run with cluster admin privileges. Otherwise, the following warning is displayed in the prerequisite check output:
Ran CONNECTIVITY checks...[CONNECTIVITY][NETWORK_TEST_SETUP] Failed to create the network test infrastructure: failed to create echo-host-role role: error creating role: roles.rbac.authorization.k8s.io "network-prereq-6c5mt-echo-host-role" is forbidden: user "system:serviceaccount:uipath:uipathadmin" (groups=["system:serviceaccounts" "system:serviceaccounts:uipath" "system:authenticated"]) is attempting to grant RBAC permissions not currently held:
{APIGroups:["security.openshift.io"], Resources:["securitycontextconstraints"], ResourceNames:["hostnetwork-v2"], Verbs:["use"]}Ran CONNECTIVITY checks...
     ⚠ [CONNECTIVITY]
        ⚠ [NETWORK_TEST_SETUP] Failed to create the network test infrastructure: failed to create echo-host-role role: error creating role: roles.rbac.authorization.k8s.io "network-prereq-6c5mt-echo-host-role" is forbidden: user "system:serviceaccount:uipath:uipathadmin" (groups=["system:serviceaccounts" "system:serviceaccounts:uipath" "system:authenticated"]) is attempting to grant RBAC permissions not currently held:
The checks in the following table are run on each node:
Check
SQL Connection
Validates that Automation Suite can successfully connect to the SQL server for UiPath® products and shared services (such as Identity, Portal, Org Mamagement, etc.) using the SQL connection strings provided in the input.json file. This is mandatory for a successful installation.
SQL DB roles
Validates the necessary roles and permissions required by UiPath® products. This is mandatory for a successful installation.
SQL DB compatibility
Validates SQL DB compatibility requirements.
FQDN resolution
Validates that the FQDN and the sub-domains are successfully resolvable.
Object Storage API
Validates that objectstore APIs are accessible based on access information provided in the input.json file. This is mandatory for a successful installation of the UiPath® services.
Cache / Redis
Validates the connection to Redis. This is mandatory for a successful installation.
Capacity
Validates you have minimum CPU and RAM capacity on the worker nodes based on the products enabled in the input.json file.
Storage Class
Validates that the storage classes for File Storage are configured as required for Automation Suite Robots.
Optional Components
Validates that your cluster has components that you chose to exclude from the Automation Suite installation.
Ingress
Validates that the cluster ingress is configured correctly and the FQDN URL requests can reach UiPath® products.
Network Policies
Checks if the network policies configured in Automation Suite are compatible with the cluster.
Registry
Validates that Automation Suite can access the UiPath® docker registry. This is mandatory for a successful installation.
Cluster Connectivity
Validates whether the cluster communication is configured properly:
  • Between two random pods completed
  • Between pod and a multinode ClusterIP
  • Between pod and a multinode ClusterIP without a clusterIP
  • Between pod and a multinode ClusterIP using HostNetwork
  • Between pod and a multinode ClusterIP without a clusterIP set using HostNetwork
  • Between two pods colocated on the same node via ClusterIP
