Last updated Sep 10, 2025
Disaster recovery - Active/Passive
This article walks you through the core concepts and architecture of Automation Suite disaster recovery, covering Active/Passive deployments.
Ensuring continuous business automation is at the core of any automation platform. Automation Suite can withstand the complete failure of nodes, entire data centers, or regions. You can deploy Automation Suite as an Active/Passive configuration.
Automation Suite multi-site deployments in Active/Passive mode support the following scenarios:
  • Same-region deployment – Two Automation Suite clusters deployed in the same region;
  • Cross-region deployment – Two Automation Suite clusters deployed in different regions.
The following table provides details on which Automation Suite products you can deploy in Active/Passive mode.
Product
Support for Active/Passive
Orchestrator
available
Action Center
available
AI Center
available
Apps
available
Automation Ops
available
Automation Suite Robots
available
Computer Vision
available
Data Service
available
Document Understanding
available
Test Manager
available
Automation Hub
not available
Insights
not available
Note:
  • You can install products that are not supported in Disaster Recovery with Active/Passive . However, you cannot use these products when the primary cluster is down.
  • For AI Center, the training pipeline functionality is available only in the primary cluster.
