- Open API- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
Automation Hub API Guide
Last updated Nov 11, 2024
As companies are dynamic the details related to people’s departments, business units, other details change very fast. Keep these up to date in Automation Hub by using the /edituser API call.
The below example presents how to update the Business Unit and Department. To do this we'll need to identify the below 2 fields in the body of the request and add the new values corresponding to the user's current Business Unit and Department:
               user_business_unit=newbuvalue
               user_department=newdptvalue
POST
         https://{yourDomain}/automationhub_/api/v1/openapi/edituserRequest
	Authorization: Bearer [Tenant ID/Token]
  x-ah-openapi-auth: openapi-token
 data-raw '{
    "user_email": "[email protected]",
      "user_first_name": "Jane",
      "user_last_name": "Doe",
      "user_location": "Brooklyn",
      "user_department": "newdptvalue",
      "user_business_unit": "newbuvalue",
      "user_job_title": "Developer",
      "user_is_active": 0,
      "user_invite_status": 1,
      "user_roles": [
          "role_id": 6,
          "category_id": 0
          "role_id": 4,
          "category_id": 0
          "role_id": 5,
          "category_id": 3
    }	Content-Type: application/json
 data-raw '{
      "user_roles": [
          "role_id": 6,
          "category_id": 0
          "role_id": 4,
          "category_id": 0
          "role_id": 5,
          "category_id": 3
    }Response
    "message": "Resource Updated",
    "statusCode": 201,
    "data": {
        "message": "Sync Successful."
    "statusCode": 201,
    "data": {
