Automation Hub API Guide
Last updated Nov 11, 2024
Input for Category
Note:
Use the lowest Category ID in order for the whole hierarchy chain to be inputted.
Key
Value
Use Case
hierarchy
The Category values are not defined as these fields are customized by each tenant.
GET and POST request parameters
Note: You can easily extract the Category values relevant for your tenant by using the GET category call.
Example: "category=717" where 717 is a level 3 Category used in order to input the whole Category chain (the Level 1 Category, the Level 2 Category, and the Level 3 Category).
UI Correspondent:
  • Categories
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
