- Release Notes
 - Getting Started
 - Permissions
 - Starting as
 - Admin Console
 - Workspace
 - Explore
 - Dashboards
 - Share Idea or Automation
 - My Tasks
 - Notifications
 - Resources
 - Task Capture Integration
 - Automation Store
 - Email Notifications
 - Video Tutorials
 - Additional Resources
OUT OF SUPPORT
Automation Hub User Guide
Last updated Nov 11, 2024
After successfully logging in, you, as a Program Manager, need to access Workspace > Automation Pipeline in order to decide what ideas should progress in the implementation phases. Furthermore, you can check out and edit any information from the Idea Profile page as well as assign implementation teams for the shared ideas.
You are encouraged to Share Ideas and upload Components that will boost the company’s RPA assimilation.
Apart from the Automation Pipeline page, you can check out all the other options available under the Workspace module if you want to have a detailed view over:
- Your ideas;
 - Your collaborations;
 - Your components;
 - The Ideas you follow.
By accessing the Explore module you can:
- view the ideas shared by your colleagues and choose to follow the ones that drow your attention,
 - check out and download the components shared within your tenant,
 - access the Leaderboard.
