- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- Notifications
- Resources
- Task Capture Integration
- Automation Store
- Email Notifications
- Video Tutorials
- Additional Resources
Automation Hub User Guide
Customizing the High Level Assessment
linkThe High level assessment is part of the Share an Idea form that lets you assess information about the task or process proposed for automation. System Admin and other roles that have the “Customize Assessments” permission assigned can modify the High level assessment to better match the target audience and obtain a relevant idea score for their organization that will allow making informed decisions.
Go to Platform Setup in Admin Console and select the Customize assessments option, which, for the High level assessment, allows you to:
- Customize - start the customization process of the High level assessment;
- See live preview - see a preview of the Share an Idea form as it is currently published to the users;
What Can Be Customized
linkAfter selecting Customize, you can do the following:
- Add new questions;
- Reorder questions in the form;
- Change the Question Type (Multiple choice, Single choice, Free text, Free text with formatting);
- Change Question Settings (Required, Show question, Show comments section, Impacts idea score);
- Modify existing questions part of the UiPath default assessment
Add a New Question
You have the option to create additional questions either at the end or in between the existing questions.
Click on the New Question button and you can now start to add the necessary details.
Field |
Description |
Question |
Mandatory field for any question added, limited to 150 characters. |
Description |
Description can be added for each question, limited to 500 characters. |
Answer Options |
A minimum of 2 and maximum of 20 answer options should be defined for any single choice or multiple choice question; Limited to 300 characters. You can add, remove or reorder answers. |
Question Type |
You can select from 4 types available:
Settings |
You can toggle the following options:
To remove a question from the assessment, just press Delete question button. Once the customize page is saved as a draft or published, you cannot recover the deleted question.
Reorder Questions
Question Type
Questions can be of different types as follows:
Question Type |
Description |
Single Choice |
Users who fill in the Share an Idea form can select only one answer for this question type. Can impact the Idea Score. |
Multiple Choice |
Users who fill in the Share an Idea form can select multiple answers for this question type. Can impact the Idea Score. |
Free text |
Text field limited to 100 characters. It cannot impact the Idea Score since the answers are not quantifiable. |
Free text with formatting |
Text area with multiple formatting options limited to 10000 characters. It cannot impact the Idea Score since the answers are not quantifiable. |
Question Settings
The settings available for each question are detailed as follows:
Setting name |
Description |
Required |
Toggle :
Show question |
Toggle :
Show comments section |
Toggle :
Impacts idea score |
Toggle :
Question Weight Editor
The Idea Score indicator is computed as a weighted average between the questions that have the "Impacts idea score" setting ON. You can modify the weight of each question that will be taken into account in the algorithm that computes the idea score. Below you can see how to customize the weight distribution of each question from the High level assessment.
The Split evenly option allows you to decide if equal weights should be applied for all the questions or define a specific weight for every question. Keep in mind that all weights need to add up to 100.
Show only weighted questions option lets you see only the questions that impact the idea score. When toggled OFF, all the questions are shown, but only those that impact the idea score can have the points modified.
Modifying Existing Questions of UiPath Default Assessment;
Default questions from the UiPath assessment can also be customized as follows:
- First four questions can be made optional or hidden from the Share an Idea form. The comments section can be hidden and the impact idea score setting turned off. Also, the question type can be modified as needed.
The question referring to existing documentation related to the task/process helps in building a stronger case for your automation idea. You are allowed to modify its settings, the question weight, add new answer options, but you cannot do the following:
- Modify the answer scores;
- Modify the default answers;
- Delete the default answer options;
Delete the entire question.
At the end of the default questions the Assign Process Owner section is available, where you have the option to decide whether the Process Owner question should be displayed or not in the form. The purpose of this question is to select a user who will be invited to fill in a more detailed assessment for the automation idea. The question has the Required and Show question settings available.
When everything is set up, you can click the Save and publish button in the right bottom corner of the page, to publish the assessment. A pop-up message will inform you about the consequences of publishing a changed assessment will be displayed requesting you to Publish or cancel.
Note: After publishing the customized version, the business users will see the updated High level assessment in Share an Idea form.
Save as a draft option allows you to save the customized form and close the edit mode. You will be able to continue customizing the form at a later time.
If a user has an employee-driven idea draft and the high-level assessment questionnaire gets updated, a pop-up is displayed informing that the Share an idea questionnaire has been updated by an administrator and the entire form should be reviewed.
- When entering the edit mode of an idea or resuming a draft, you will see the questions and their answers with the updated text.
- When resuming a draft, the disabled/deleted questions will no longer be displayed in the form.
- When resuming a draft, the new questions added in the customization page will be displayed in the form. The user needs to review the entire form and ensure that all mandatory questions have been answered to successfully submit the form.
Selecting Preview lets you see how the assessment form will look like with the changes made.
You can always click on Cancel button and discard any changes made, or Reset to default if you wish to cancel all customization changes done and return to the UiPath default High level assessment.
Impact on Existing Automation Profiles
linkPublishing a customized version of the High level assessment impacts the existing Automation Profiles as described below:
Customization action |
Impact |
Questions or descriptions are edited |
Editing an existing automation idea will show the updated questions and descriptions. |
New answer options are added or removed |
Editing an existing automation idea will show the updated answers list. If a selected answer was removed from a question that is marked as mandatory, you will need to select another answer to submit the assessment. The Idea Score will be recalculated if you select a newly added answer for a question that impacts the score. |
Questions are disabled or deleted |
All questions that had an answer provided will be displayed grayed out in the view mode of the automation profile with a note that they are no longer part of the assessment. |
Weights are modified or the Impacts idea score setting is modified for at least one question |
The idea score is recalculated for existing automation ideas only if you go in the edit mode of a certain automation idea and save the About page. |
New mandatory questions are added |
When resuming a drafted automation idea, the newly added questions will be mandatory for submitting the form. When editing an existing automation idea, it will be optional to answer the new questions in order to save the About page. |
New optional questions are added |
Editing an existing automation idea or resuming a draft will show the new questions. It will be optional to answer the new questions to save the About page. |
